17255 Discussions
Undefined module: altera_pll was used
I'm simulating a Quartus design in Active-HDL and I'm getting the following error:
Undefined module: altera_pll was used. Port connection rules will not be checked at such instantiations.
Where can the altera_pll simulation be found, so I can add it to the project?
If you want to simulate your PLL you have to use the <pll_megacore_name>.vho or <pll_megacore_name>.vo file in the <pll_megacore_name>_sim directory and used the Altera library altera_lnsim.
I also have a same problem. I've used .vo file and altera_lnsim.sv file. Then I've seen a message like below.
# ** Warning: (vsim-3017) <work_area>/sim_PLL_ArriaV/RTL/ALT_PLL_CLK.vo(51): [TFMPC] - Too few port connections. Expected 25, found 5.
ALT_PLL_CLK.vo is a generated file. I've checked altera_lnsim.sv file and there were 25 ports in the altera_pll
module. But there are only 5 ports in altera_pll in ALT_PLL_CLK.vo.
Could you tell me what is a problem?
