17268 Discussions
Unexpected Error in JTAG server Bad TAP position
ims19
Trying to run the Program/Configure option with the BSP base.sof but running into the error of Bad Tap position
Attached picture for reference
Quartus Pro 20.04
Fakhrul
Fakhrul
Hi ims19,
I wish to follow up with you about this case. Do you have any updates?
Otherwise, this thread will be idling and marked as inactive, thus it will be transitioned to community support because there is no update received from you in a while.
Fakhrul
Fakhrul
As we do not receive any response from you to the previous notification that we provided.
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
ims19
There are no pins to set on the card itself for the first link.
I did try using the Auto detect feature when gathering the information on the card, it does pull the information. After selecting the base.sof to program is when running into the Bad Tap Position
