Hello dear friends,
I am having an unsigned number of the input and need to sign extend it and negate (2s representation) if in the specific condition occurs (say if sign=1, to simplify) Here is my code in SystemVerilog: module signed_unsigned ( sign, clk, data_in, data_out); input logic sign; input logic clk; input unsigned [7:0] data_in; output signed [8:0] data_out; always_ff @ (posedge clk) begin if (sign) data_out <= -data_in; else data_out <= data_in; end endmodule It looks like it analyzed properly in Quartus (see RTL representation in the attachment). However, when I simulate in Modelsim it doesn't show the correct result. In the testbench I have a clock generator and just assignments to the data_in. I expect to see 101 value for 0xFF, 156 for 0xAA, etc but nothing happens. the numbers are same What can be wrong? I am very confused. Cheers,Link Copied
I will use signed(for unsigned addt one MSB at zero)
e.g. assuming 8 bit signed: if... data <= input; else data <= -input end- Mark as New
This works for me after making one correction unrelated to the signed issue. data_out needs to be a variable in order to make procedural assignments to it. You have it declared as a wire. (you are also using Verilog-1995 style ports, which I updated)
input logic sign,
input logic clk,
input unsigned data_in,
output logic signed data_out
if (sign)
else
end
endmodule
It would have helped to show the testbench you were using. Here is what I used. module top;
bit clk, sign;
logic unsigned data_in;
logic signed data_out;
always# 5 clk++;
initial begin
sign=1;
data_in = 8'hff;
@(negedge clk)
$displayh(data_in,,data_out);
data_in = 8'hAA;
@(negedge clk)
sign=0;
data_in = 8'hff;
@(negedge clk)
data_in = 8'hAA;
@(negedge clk)
$finish;
end
signed_unsigned su(.*);
endmodule : top
And the output I got # Loading work.top(fast)
# run -all
# ff 101
# aa 156
# ff 0ff
# aa 0aa
# ** Note: $finish : signed.sv(25)
Thank you, dave_59. It is working now! My testbench was a bit crooked too :)
