17249 Discussions
Up-to-date example design
Hi all,
I try to synthesize and use design example from Intel.
https://www.altera.com/support/support-resources/design-examples/design-software/opencl/library-design-example.html
Does anybody have managed to compile the example 2 for linux with the last version 17.1 ? I could not make it.
The errors seem to come from the IP that are not compatible from the 2 version of the tool (and other stuff). Does anyone has an version for the 17.1 tool ?
Thanks in advance !
b
Have you checked it with version 16.1?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Hi Anand,
I did not checked with version 16.1. I'm rather confident it's OK with this one because it is the officially supported version.
I'm more interested in a solution for upgrading the design to make it work with 17.1 version (some design are working when auto-upgraded via Quartus).
