17255 Discussions
Update Cyclone III to Cyclone 10
hueslei
I need update my Cyclone II to Cyclone 10, but when I try compile the code, Quartus return error message below:
" Error (292019): IP core Nios II Processor (6AF7_00A2) not supported in device family Cyclone 10 LP. Choose a new device family or upgrade your IP core to a newer version. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-filter.html and search for this specific error message number.
Error (292019): IP core Nios II Processor (6AF7_00A2) not supported in device family Cyclone 10 LP. Choose a new device family or upgrade your IP core to a newer version. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-filter.html and search for this specific error message number. "
I use Quartus II 7.2sp3 with valide license.
To update I started using  Quartus Prime Lite Edition 20.1.
I need a new license to be able compile the code or is it a bug of Quartus Prime?
jozephka99
New Contributor II
If you use Cyclone 10 LP device you can use Quartus Prime Lite, if you use other Cyclone 10 models you cannot use Lite edition and you must have new license for paid editions.
hueslei
I intend use Cyclone 10 LP with Quartus PRime Lite version 20.1 and I tested right now the version 18.1. The same error occur.
ak6dn
Valued Contributor III
The error message is pretty obvious and explicit. Your existing project on the Cyclone II uses a specific Nios II processor IP core.
In the new device you select, the Cyclone 10 LP, that Nios II processor core you are using is NOT supported.
So you can't just change the device family, change the Quartus version, and recompile your existing design.
You have to replace the Nios II core with a supported/updated Nios II core on your new device (Cyclone 10 LP).
hueslei
Maybe it's obvius to you!!
I asked it because I know others example they performed procedure exactly like me and the project compile without problems.
Anyway, thanks for your comment.
ak6dn
Well:  "IP core Nios II Processor (6AF7_00A2) not supported in device family Cyclone 10 LP. Choose a new device family or upgrade your IP core to a newer version." is pretty straightforward.
It is not uncommon at all to have to upgrade your IP module to a newer version if you move to a newer version of Quartus (moving from v7.2 to v20.1 is a significant change), and especially if you change the device family. You are doing both.
EricMunYew_C_Intel
You will need to create a new Nios II from beginning, and not to copy the old Nios design.
EricMunYew_C_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
