i have got a code from some forum regarding NCO(NUMERICALLY CONTROLLED OSCILLATOR).
but when i compile the code in MODELSIM,it gives just 1 ERROR: ** Error: E:/project/nco1.vhd(67): near "constant": expecting: END ** Error: E:/project/nco1.vhd(68): near "constant": expecting: END HERE IS THE CODE FOR NCO: -------------------------------------------------------------------------- -- -- -- Numeric Oscillator -- -- with quadrature output and pipeline -- -- Not usable at full clock frequency (clk_en always '1') !! -- -- -- -- -- -------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.math_real.all; ENTITY nco IS GENERIC ( NNCO : INTEGER := 10; -- output resolution NAKKUI : INTEGER := 10; -- akku integer bits NAKKUF : INTEGER := 6; -- akku fractional bits FC : REAL := 0.01; -- center frequency / fclk resp. fclk_en NFRQ : INTEGER := 11 -- frequeny input resolution ); PORT ( CLK : IN STD_LOGIC; RESET : IN STD_LOGIC := '0'; CLK_EN : IN STD_LOGIC; -- clock qualifier FRQ : IN SIGNED(NFRQ-1 downto 0) := (others => '0'); -- optional frequency modulation/tuning input DPHI : IN SIGNED(7 downto 0) := (others => '0'); -- optional q output phaseshift I : OUT SIGNED(NNCO-1 downto 0); Q : OUT SIGNED(NNCO-1 downto 0); UPDATE : OUT STD_LOGIC; -- new output data available SYNC : OUT STD_LOGIC -- I output crosses phase zero ); END nco; ARCHITECTURE rtl OF nco IS CONSTANT FCI : INTEGER := INTEGER(REAL(2**(NAKKUI+NAKKUF))*FC); CONSTANT ROMSIZE : INTEGER := 2**(NAKKUI-1); CONSTANT ROMMAX : INTEGER := 2**(NNCO-1)-1; TYPE SINTAB IS ARRAY(0 TO ROMSIZE-1) OF STD_LOGIC_VECTOR (NNCO-2 DOWNTO 0); SIGNAL SINROM: SINTAB; SIGNAL romaddress : STD_LOGIC_VECTOR (NAKKUI-2 DOWNTO 0); SIGNAL romdata : STD_LOGIC_VECTOR (NNCO-2 DOWNTO 0); SIGNAL romaddress2 : STD_LOGIC_VECTOR (NAKKUI-2 DOWNTO 0); SIGNAL akku : UNSIGNED (NAKKUI+NAKKUF-1 downto 0); SIGNAL akku2 : UNSIGNED (1 downto 0); -- Q quadrant info SIGNAL sgn1 : STD_LOGIC; SIGNAL sgn2 : STD_LOGIC; SIGNAL clk_en_v : STD_LOGIC; SIGNAL clk_en_v2 : STD_LOGIC; SIGNAL clk_en_v3 : STD_LOGIC; BEGIN -- For FPGA devices, this construct infers ROM sine table, -- RAMless devices (MAX II) must use LE based table instead -- only the 0..pi positive half is represented GENROM : FOR idx in 0 TO ROMSIZE-1 GENERATE CONSTANT x: REAL := SIN(real(idx)*MATH_PI/real(ROMSIZE)); CONSTANT xn: UNSIGNED (NNCO-2 DOWNTO 0) := CONV_UNSIGNED(INTEGER(x*real(ROMMAX)),NNCO-1); BEGIN SINROM(idx) <= STD_LOGIC_VECTOR(xn); END GENERATE GENROM; PROCESS (clk, reset) VARIABLE n_akku : SIGNED (NAKKUI+NAKKUF-1 downto 0); VARIABLE ra_s : SIGNED (NAKKUI-2 DOWNTO 0); BEGIN if reset = '1'then akku <= (others => '0'); i <= (others => '0'); q <= (others => '0'); clk_en_v <= '0'; clk_en_v2 <= '0'; clk_en_v3 <= '0'; UPDATE <= '0'; SYNC <= '0'; romaddress <= (others => '0'); romaddress2 <= (others => '0'); elsif rising_edge(clk) THEN clk_en_v <= CLK_EN; clk_en_v2 <= clk_en_v; clk_en_v3 <= clk_en_v2; UPDATE <= clk_en_v3; IF CLK_EN = '1' then n_akku := signed(akku) + fci + frq; romaddress <= STD_LOGIC_VECTOR(n_akku(akku'left-1 downto NAKKUF)); romaddress2(romaddress2'left-1 downto 0) <= STD_LOGIC_VECTOR(n_akku(akku'left-2 downto NAKKUF)); romaddress2(romaddress2'left) <= NOT n_akku(akku'left-1); akku <= unsigned(n_akku(akku'left downto 0)); if akku(akku'left)='1' and n_akku(akku'left)='0' then sync <= '1'; else sync <= '0'; end if; akku2 <= unsigned(n_akku(akku'left downto akku'left-1)) + 1; ELSIF clk_en_v = '1' THEN sgn1 <= akku(akku'left); sgn2 <= akku2(1); ra_s := SIGNED(romaddress2)+dphi; romaddress <= STD_LOGIC_VECTOR(ra_s); END IF; IF clk_en_v2 = '1' THEN if sgn1 = '0' then i <= SIGNED('0'& romdata); else i <= -SIGNED('0'& romdata); end if; ELSIF clk_en_v3 = '1' THEN if sgn2 = '0' then q <= SIGNED('0'& romdata); else q <= -SIGNED('0'& romdata); end if; END IF; romdata <= SINROM(CONV_INTEGER(UNSIGNED(romaddress))); end if; END PROCESS; END rtl;Link Copied
Looks like ModelSim doesn't support a block declarative part in a generate statement. Apparently, I never checked. You have to use a different method for sine table generation, e.g. an initializing function.
This code compiles for me in modelsim 6.4a fine.
Is there any reason why you have SINROM as a signal an not a constant? you could use a function to generate the rom instead of a generate statement.
