Using I/O registers
Can anyone tell me how I can specify that I want to enable the registers/flipflops at the input buffers (ie. use register packing at the I/O buffers) in Quartus II?
I have spent a few minutes searching for this in Q II with no obvious answer.
I am currently using the Cyclone II.
A picture shows it all ...
Thanks that's indeed what I meant, but the "Fast Input" option disappears if the I/O type is LVDS. Is it not possible to have fast inputs with LVDS?
You probably have DDR input on those pins too, in Cyclone DDR is done inside the logic fabric and not in the IO-ring so the Fast Input Register is not possible.
