Hi guys, I'm new here. What would be the VDHL code for this Mealy machine? Thanks
A sequential circuit with two Dflip-flops Aand B, two inputs, xand y; and one output z specified by the following next-state and output equations. A(t +1)=xy’ +xB B(t +1)=xA+xb’ z=ALink Copied
Why not show the code you've written and what problems you're having
library ieee;
use ieee.std_logic_1164.all; entity lab2exercise2 is port ( clk : in std_logic; data_in1 : in std_logic; data_in2 : in std_logic; reset : in std_logic; data_out : out std_logic_vector(1 downto 0) ); end lab2exercise2; architecture rtl of lab2exercise2 is -- Build an enumerated type for the state machine type state_type is (a, b, c, d); -- Register to hold the current state signal state : state_type; signal clk_1hz : std_logic:= '0'; begin process(clk) variable counter : integer := 0; variable edge_toggle : std_logic := '0'; begin if (rising_edge(clk)) then counter := counter + 1; if (counter = 25000000) then edge_toggle := not edge_toggle; counter := 0; end if; end if; clk_1hz <= edge_toggle; end process; process (clk_1hz, reset) begin if reset = '1' then state<= a; elsif (rising_edge(clk_1hz)) then -- Determine the next state synchronously, based on -- the current state and the input case state is when a=> if((data_in1 = '0') & (data_in2 = '0'))then state<=a; if((data_in1 = '1') & (data_in2 = '0'))then state<=a; if((data_in1 = '1') & (data_in2 = '1')) then state<=a; else state<=c; end if; when b=> if ((data_in1 = '0') & (data_in2 = '0')) then state<=a; else if ((data_in1 = '1') & (data_in2 = '0'))then state<=d; else if ((data_in1 = '1') & (data_in2 = '1'))then state<=d; else state<=c; end if; when c=> if ((data_in1 = '1') & (data_in2 = '0')) then state<=a; else if ((data_in1 = '1') & (data_in2 = '1')) then state<=a; else if ((data_in1 = '0') & (data_in2 = '1')) then state<=d; else state<=b; end if; when d=> if ((data_in1 = '0') & (data_in2 = '1'))then state<=d; else if((data_in1 = '1') & (data_in2 = '0')) then state<=d; else if((data_in1 = '1') & (data_in2 = '1')) then state<=d; else state<=b; end if; end case; end if; end process; -- Determine the output based only on the current state -- and the input (do not wait for a clock edge). process (state, data_in1, data_in2) begin case state is when a=> if((data_in1 = '0') & (data_in2 = '0'))then data_out<= "000"; if((data_in1 = '1') & (data_in2 = '0'))then data_out<= "000"; if((data_in1 = '1') & (data_in2 = '1')) then data_out<= "000"; else data_out<= "010"; end if; when b=> if ((data_in1 = '0') & (data_in2 = '0')) then data_out<= "000"; else if ((data_in1 = '1') & (data_in2 = '0'))then data_out<= "011"; else if ((data_in1 = '1') & (data_in2 = '1'))then data_out<= "011"; else data_out<= "010"; end if; when c=> if ((data_in1 = '1') & (data_in2 = '0')) then data_out<= "100"; else if ((data_in1 = '1') & (data_in2 = '1')) then data_out<= "100"; else if ((data_in1 = '0') & (data_in2 = '1')) then data_out<= "111"; else data_out<= "101"; end if; when d=> if ((data_in1 = '0') & (data_in2 = '1'))then data_out<= "111"; else if((data_in1 = '1') & (data_in2 = '0')) then data_out<= "111"; else if((data_in1 = '1') & (data_in2 = '1')) then data_out<= "111"; else data_out<= "111"; end if; end case; end process; end rtl; This is my code. I tried running it but I always get error 10500 at lines "when b=>, when c=> and when d=>" and "end processes".- Mark as New
1. It`s syntax error about If statement, follow below syntax,if condition1 then
target := expression1;
elsif condition2 then
target := expression2;
elsif conditionN-1 then
target := expressionN-1;
else
target := expressionN;
end if;
2. if((data_in1 = '0') & (data_in2 = '0'))then -------- Here replace “&” with and 3. data_out<= "000"; ----- here data_out is 2 bit so assign 2 bits like : data_out<= "00"; Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
Already edited the code but i still get errors at when b=>, when c=> and when d=>" and "end processes".
All of the errors are 10500 VHDL Syntax error at near text "when"; expecting "if", identifier, etc...sorry couldn't really recall it.- Mark as New
I would suggest go through the VHDL Basic online training, https://www.altera.com/support/training/course/ohdl1110.html check modified code,library ieee;
port
clk : in std_logic;
end lab2exercise2;
begin
process(clk)
begin
counter := 0;
end if;
end if;
end process;
begin
if reset = '1' then
state<= a;
case state is
when a=>
if((data_in1 = '0') and (data_in2 = '0'))then
state<=a;
elsif((data_in1 = '1') and (data_in2 = '0'))then
state<=a;
elsif((data_in1 = '1') and (data_in2 = '1')) then
state<=a;
else
state<=c;
end if;
when b=>
if ((data_in1 = '0') and (data_in2 = '0')) then
state<=a;
elsif ((data_in1 = '1') and (data_in2 = '0'))then
state<=d;
elsif ((data_in1 = '1') and (data_in2 = '1'))then
state<=d;
else
state<=c;
end if;
when c=>
if ((data_in1 = '1') and (data_in2 = '0')) then
state<=a;
elsif ((data_in1 = '1') and (data_in2 = '1')) then
state<=a;
elsif ((data_in1 = '0') and (data_in2 = '1')) then
state<=d;
else
state<=b;
end if;
when d=>
if ((data_in1 = '0') and (data_in2 = '1'))then
state<=d;
elsif((data_in1 = '1') and (data_in2 = '0')) then
state<=d;
state<=d;
else
state<=b;
end if;
end case;
end if;
end process;
begin
case state is
when a=>
data_out<= "00";
data_out<= "00";
data_out<= "00";
else
data_out<= "01";
end if;
when b=>
data_out<= "00";
data_out<= "11";
data_out<= "11";
else
data_out<= "10";
end if;
when c=>
data_out<= "10";
data_out<= "10";
data_out<= "11";
else
data_out<= "10";
end if;
when d=>
data_out<= "11";
data_out<= "11";
data_out<= "11";
else
data_out<= "11";
end if;
end case;
end process;
end rtl;
in VHDL, & is the concatenate operator, not the "and" operator.
You need to replace all & with and- Mark as New
Have you resolved the issue? Do you need further assistance? Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)- Mark as New
Here's the corrected code.. see if you can find out your basic mistakes.. This one compiles without any issues.
library ieee;
port (
clk : in std_logic;
data_out : out std_logic_vector(2 downto 0)
end lab2exercise2;
begin
process(clk)
begin
counter := 0;
end if;
end if;
end process;
begin
if reset = '1' then
state<= a;
case state is
when a=>
state<=a;
elsif(data_in1 = '1' and data_in2 = '0')then
state<=a;
state<=a;
else
state<=c;
end if;
when b=>
state<=a;
state<=d;
state<=d;
else
state<=c;
end if;
when c=>
state<=a;
state<=a;
state<=d;
else
state<=b;
end if;
when d=>
state<=d;
state<=d;
state<=d;
else
state<=b;
end if;
end case;
end if;
end process;
begin
case state is
when a=>
data_out<= "000";
data_out<= "000";
data_out<= "000";
else
data_out<= "010";
end if;
when b=>
data_out<= "000";
data_out<= "011";
data_out<= "011";
else
data_out<= "010";
end if;
when c=>
data_out<= "100";
data_out<= "100";
data_out<= "111";
else
data_out<= "101";
end if;
when d=>
data_out<= "111";
data_out<= "111";
data_out<= "111";
else
data_out<= "111";
end if;
end case;
end process;
end rtl;
Topic Options
