17247 Discussions
VHDL Coding Help - Altera DE1 Board
Why does Quartus throws multiple warnings when the pin assignments are done and not when the pins are not assigned.
Im not sure what you're asking here? no one will do your work for you.
If you post your code, and the problems you're having with it, then we can help.
