VHDL Preprocessor?
Hello!
I am trying to make a reusable piece of code which has some generics on top and some constant declarations following. My problem is that depending on some generic values the constants need to have different values. Since i cannot use code outside before the "begin" keyword of the "architecture" then how can I do it? I cannot find any preprocessor directives like "define" for VHDL...
Does anybody have a solution for this?
Thanks in advance
Please write the sample code that you wants to be realized.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity MyEntity is generic ( PARAM_SIGN : NATURAL := 0 -- 0: above zero, 1: below zero ); port ( clock : in STD_LOGIC; reset : in STD_LOGIC ); end MyEntity; architecture RTL of MyEntity is # if PARAM_SIGN = 0 constant myconst1 : SIGNED(15 DOWNTO 0) := TO_SIGNED(1000,16); # else constant myconst1 : SIGNED(15 DOWNTO 0) := TO_SIGNED(0,16); # end if begin .................................. end RTL;
VHDL has no pre-processor, instead you must write functions to set the values:
function create_my_const_1 return signed is begin if PARAM_SIGN = 0 then return to_signed(1000, 16); else return to_signed(0,16); end if; end function create_my_const_1; constant my_const1 : signed(15 downto 0) := create_my_const_1;
"Ifdef" is "if generate" to be equivalent with VHDL.
begin above_zero : if PARAM_SIGN=0 generate process(clock) constant myconst1 : SIGNED(15 DOWNTO 0) := TO_SIGNED(1000,16); begin if rising_edge(clock) then dout <= myconst1; end if; end process; end generate; below_zero : if PARAM_SIGN=1 generate process(clock) constant myconst1 : SIGNED(15 DOWNTO 0) := TO_SIGNED(0,16); begin if rising_edge(clock) then dout <= myconst1; end if; end process; end generate;
ifdef and if generate are NOT the same thing.
You could not use a generate to set the value of a constant available to the whole file. Using a generate like you suggest would lead to a doubling up of code (not a good idea).
Different ways to do it. In this case, the shortest is
constant myconst1 : SIGNED(15 DOWNTO 0) := TO_SIGNED((1-PARAM_SIGN)*1000,16);
--- Quote Start ---
--- Quote End ---
Yes, but it requires 'decoding' every time the poor chap after you has to read it.
I wrote a 'ternary' function (with almost a dozen overloads) in my utilities package.
constant myconst2 : signed(15 downto 0) := to_signed( ternary( PARAM_SIGN = 1, 0, 1000 ) , 16) ;
It is not as nice as the C construct ? : though but it saves a lot of 'if then else' clutter.
