17268 Discussions
help me find issues in my code gps baseband
I was hoping others here could help me identify issues in my code modules. I beleive I may have timing/metastability issues but I am not certain. These modules are part of a gps receiver project I've been working on.
sysclk = 50 MHz main real clock on fpga
sampleclk = 5 MHz by 10 counter divider, durration 1 sysclk cycle
My CA code generator
module CAcode(nextChip, sysclk, reset, Tap1, Tap2, chip, codeReset, codeDelay); input reset; input sysclk; input nextChip; input Tap1; //bits needed for index input Tap2; //bits needed for index input codeDelay; output chip; output reg codeReset; //readable on sysclk reg G1; reg G2; reg chipCount; reg flagReset; reg countDelay; always @ (posedge nextChip) //must be on posedge to maintain correct freq of chip rate begin chipCount <= chipCount + 12'd1; G1 <= {G1, (G1 ^ G1)}; //shifts 9 and xors last bit G2 <= {G2, (G2 ^ G2 ^ G2 ^ G2 ^ G2 ^ G2)};//shifts 9 and xors last bit if(chipCount > 1023) begin chipCount <= 0; G1 <= 10'b1111111111; //initialize G1 G2 <= 10'b1111111111; //initialize G2 flagReset <= 1; countDelay <= 0; end else flagReset <= 0; //flagReset takes 1.023MHz timing to reset to 0 //if in search mode, delay is always active, inactive in track mode //should cause 1 chip delay in code from normal reset timing ??? if(codeDelay) begin if(countDelay == 0 && chipCount == 1) //effectively delays code by 1 chip ever start of millis cycle begin chipCount <= 0; countDelay <= 1; G1 <= 10'b1111111111; //initialize G1 G2 <= 10'b1111111111; //initialize G2 end end end //of nextChip always @ (posedge sysclk) //should make certain codeReset is readable on a sysclk begin codeReset <= flagReset; //may be several sysclk cycles long end assign chip = G1 ^ G2 ^ G2; //set current chip output endmodule //CA code
My code timing NCO
//This is proven to chip at desired rate by oscilliscpoe module NCO_chipRate(sysclk, reset, cntl_word, chip_enable, nextChip, nco_val, get_nco_val); input sysclk, reset; input cntl_word; input get_nco_val; output chip_enable; //late, prompt,early output nextChip; output reg nco_val; reg advanceFlag; reg chip_status; reg accum_reg; reg cycle_count_reg; wire phase_key; wire accum_sum; wire accum_carry; wire combined_carr_value; // 30 bit phase accumulator always @ (posedge sysclk) begin if (reset) begin accum_reg <= 0; cycle_count_reg <= 0; end else begin accum_reg <= accum_sum + cntl_word; if (get_nco_val) begin nco_val <= combined_carr_value; // latch in carrier value, then... cycle_count_reg <= 0; // reset counter end else if (accum_carry) begin cycle_count_reg <= cycle_count_reg + 1'b1; end end end // outputs half and full chip signal per cycle always @ (posedge sysclk) // 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 begin if(phase_key == 4'd4) begin chip_status <= 1; chip_status <= 0; chip_status <= 0; end else if(phase_key == 4'd8) begin chip_status <= 0; chip_status <= 1; chip_status <= 0; end else if(phase_key == 4'd12) begin chip_status <= 0; chip_status <= 0; chip_status <= 1; end if(phase_key == 4'd15) advanceFlag <= 1; //signal to advance chip coder else advanceFlag <= 0; end assign accum_sum = accum_reg; assign accum_carry = accum_sum; assign phase_key = accum_sum; //for controller value reading assign combined_carr_value = accum_reg; assign combined_carr_value = cycle_count_reg; assign nextChip = advanceFlag; assign chip_enable = chip_status; endmodule
my adder section partial code
//update current chip value on time signal always @ (posedge chip_enable) //early begin Echip <= chip_in; end always @ (posedge chip_enable) //prompt chip begin Pchip <= chip_in; end always @ (posedge chip_enable) //late begin Lchip <= chip_in; end //////////////////////////// generated CARRIER MULTIPLY ///////////////////////////// //this multiplies Imag, Qmag input by generated carrier split I/Q assign i_mix = !Iin; assign i_mix = Iin | Igen; assign i_mix = Iin & Igen; assign q_mix = !Qin; assign q_mix = Qin | Qgen; assign q_mix = Qin & Qgen; //multiplies Isign and Qsign with generated carrier split I/Q //instead of like sign cancelling it produces a positive resultAng //unlike signs produce negative result assign q_sign = !(Qin ^ Qgen); assign i_sign = !(Iin ^ Igen); //////////////////////// data ADDER portion ///////////////////////////// always @ (posedge sampleclk) begin //put newest value into shift register buff_Qearly <= {buff_Qearly, (q_sign ^ Echip)}; buff_Iearly <= {buff_Iearly, (i_sign ^ Echip)}; //add newest to sum and subtract oldest from sum sum_Iearly <= sum_Iearly + buff_Iearly - buff_Iearly; sum_Qearly <= sum_Qearly + buff_Qearly - buff_Qearly; //put newest value into shift register buff_Qprompt <= {buff_Qprompt, (q_sign ^ Pchip)}; buff_Iprompt <= {buff_Iprompt, (i_sign ^ Pchip)}; //add newest to sum and subtract oldest from sum sum_Qprompt <= sum_Qprompt + buff_Qprompt - buff_Qprompt; sum_Iprompt <= sum_Iprompt + buff_Iprompt - buff_Iprompt; //put newest value into shift register buff_Qlate <= {buff_Qlate, (q_sign ^ Lchip)}; buff_Ilate <= {buff_Ilate, (i_sign ^ Lchip)}; //add newest to sum and subtract oldest from sum sum_Qlate <= sum_Qlate + buff_Qlate - buff_Qlate; sum_Ilate <= sum_Ilate + buff_Ilate - buff_Ilate; end always @ (posedge codeReset) begin if(sum_Iprompt > 2500) lock_flag <= 3'b001; //else if(sum_Iprompt > 2750) lock_flag <= 3'b011; //else if(sum_Iprompt > 3500) lock_flag <= 3'b111; else lock_flag <= 3'b000; end
Any and all constructive criticisim is welcome.
