VHDL Question
[INDENT]I'm trying to create a square wave and I'm converting code from verilog and im getting the below error. Any help would be great thanks
Error (10327): VHDL error at SquareWave.vhd(36): can't determine definition of operator ""-"" -- found 0 possible definitions
[CODE]
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
ENTITY SquareWave IS
PORT (
clk : IN std_logic;
rst_n : IN std_logic;
sq_wave : OUT std_logic
END SquareWave;
ARCHITECTURE BEHAVORIAL OF SquareWave IS
-- Input clock is 400Hz
signal CLOCK_FREQUENCY : Time := 2500000 ns;
signal sq_wave_reg : std_logic := '0';
begin
sq_wave <= sq_wave_reg;
process (clk)
-- Counter for toggling of clock
variable counter : integer;
begin
if (rst_n /= rst_n) then
counter := 8;
sq_wave_reg <= '1';
else
-- If counter is zero, toggle sq_wave_reg
if (counter = 8) then
sq_wave_reg <= sq_wave_reg;
-- Generate 1Hz Frequency
counter := CLOCK_FREQUENCY/2 - 1;
-- Else count down
else
counter <= counter - 1;
end if;
end if;
end process;
END BEHAVORIAL;
counter is a variable, so you should have := instead of <= like you did just above.
I'm afraid your code is completely broken and would not work in any language. A VHDL process is not the same as a verilog always@. You need to wait on the clk. sq_wave_reg is not a register.
When do you expect "if (rst_n /= rst_n) then" to be true? You probably meant "if rst_n = '0' then"
You never change sq_wave_reg. You probably mean "sq_wave_reg <= not sq_wave_reg;"
Is this supposed to be synthesizable? Your comments say you want a 1 Hz wave from a 400 Hz clock. That means you should toggle every 200 clock cycles. Your CLOCK_FREQUENCY is meaningless.
Here is a sawtooth wave I found, i'm trying to get a 400Hz square wave, it compiles, any help will be appreciated. Thanks
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity SquareWave is port (clk : in std_logic; wave_out : out std_logic_vector(7 downto 0); reset :in std_logic ); end SquareWave; architecture Behavioral of SquareWave is signal count : integer := 0; begin process(clk,reset) begin if(reset = '1') then count <= 0; elsif(rising_edge(clk)) then if(count = 10000000000) then count <= 0; else count <= count + 1; end if; end if; end process; wave_out <= conv_std_logic_vector(count,8); end Behavioral;
Check your warnings. You have "count" (a 32-bit integer) going to ten billion. This is not a sensible way to make sawtooth wave in any event.
You seem to want to do this without even a basic understanding of VHDL. Find a good tutorial on VHDL and learn it. Then making a square wave will be trivial. I'm afraid my favorite VHDL books are all out of print, but there are good ones out there.
search for books on this forum then you'll find recommendations
chjones2008, sorry if my comments came across as a bit terse. The intent was to be helpful. It's been a while, but I had a terrible time learning VHDL at first. The key for me, coming from C/C++, was understanding that VHDL is creating hardware and to think in terms of flip-flops and combinational logic. The two books that helped:
"HDL Chip Design" by Douglas J Smith
"Essential VHDL RTL Synthesis Done Right" by Sundar Rajan
Many VHDL books are voluminous tomes on the language. These are Kernighan&Ritche like and help incrementally learn the language and show what logic a given bit of code with synthesize.
