17255 Discussions
VHDL - Writing To Registers
I want to use four push buttons as inputs and three seven-segment LED displays as outputs. Two push buttons should step up and down through the sixteen RAM locations; the other two should increment and decrement the contents of the currently-displayed memory location. One seven segment display should show the current address (0–F), and two others should display the contents of that location in hexadecimal (00–FF). This is my code to attempt to do this (I haven't implemented the display yet):
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity raminfr is
port (
clk : in std_logic;
we : in std_logic;
do : out unsigned(7 downto 0)
end raminfr;
architecture rtl of raminfr is
type ram_type is array (0 to 15) of unsigned(7 downto 0);
signal RAM : ram_type;
signal read_a : unsigned(3 downto 0);
signal a : unsigned(3 downto 0);
signal di : unsigned(7 downto 0);
signal clock : std_logic;
signal key : std_logic_vector(3 downto 0);
begin
U1: entity work.lab1 port map (
clock =>clock,
key => key,
register_counter => a,
value_counter => di
process (clk)
begin
if rising_edge(clk) then
if we = '1' then
RAM(to_integer(a)) <= di;
end if;
read_a <= a;
end if;
end process;
do <= RAM(to_integer(read_a));
end rtl;
library ieee;
entity lab1 is
port(
clock : in std_logic;
key : in std_logic_vector(3 downto 0);
value_counter : buffer unsigned(7 downto 0) ;
register_counter : buffer unsigned(3 downto 0)
end lab1;
architecture up_and_down of lab1 is
signal value_in_ram : unsigned(7 downto 0);
signal clk : std_logic;
signal we : std_logic;
begin
U1: entity work.raminfr port map (
do=>value_in_ram,
clk=>clk,
we=>we
process(clock, value_counter, register_counter)
begin
if rising_edge(clock) then
if (key(3)='0' and key(2)='0' and key(1)='1' and key(0)='0') then
value_counter <= value_counter + "1";
elsif (key(3)='0' and key(2)='0' and key(1)='0' and key(0)='1') then
value_counter <= value_counter - "1";
elsif (key(3)='1' and key(2)='0' and key(1)='0' and key(0)='0') then
register_counter<= register_counter + "1";
value_counter <= value_in_ram;
elsif (key(3)='0' and key(2)='1' and key(1)='0' and key(0)='0') then
register_counter<= register_counter - "1";
end if;
end if;
end process;
end architecture up_and_down;
When I try to compile this, I get the following errors repeating over and over:
Error (12051): Project too complex: hierarchy path is too long
Error (12052): Entity "lab1" is instantiated by entity "raminfr"
Error (12052): Entity "raminfr" is instantiated by entity "lab1"
This is obviously due to the fact that I have port mapped each entity in the other, but I don't know any other way to accomplish what I want to accomplish. Can somebody suggest alternatives?
What's the purpose with including lab1 into ram? You only need to include ram into lab1.
Review your code.
