- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have an FPGA (Cyclone II) with four push buttons - the two left most ones should cycle up and down the 16 registers, while the two right most ones should increment and decrement the value stored in this register. Here is my attempt at the code to do this:
entity raminfr is --inferring the RAM here port ( clk : in std_logic; we : in std_logic; a : in unsigned(3 downto 0); di : in unsigned(7 downto 0); do : out unsigned(7 downto 0) ); end raminfr; architecture rtl of raminfr is type ram_type is array (0 to 15) of unsigned(7 downto 0); signal RAM : ram_type; signal read_a : unsigned(3 downto 0); begin U1: entity work.lab1 port map ( --ERROR ON THIS LINE register_counter => a, value_counter => di ); process (clk) begin if rising_edge(clk) then if we = '1' then RAM(to_integer(a)) <= di; end if; read_a <= a; end if; end process; do <= RAM(to_integer(read_a)); end rtl; --lab1 starts here library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity lab1 is port( clock : in std_logic; key : in std_logic_vector(3 downto 0); value_counter : out unsigned(7 downto 0) ; --value to be written to register register_counter : out unsigned(3 downto 0) --register to write value to ); end lab1; architecture up_and_down of lab1 is --actual button logic here begin process(clock) begin if rising_edge(clock) then if (key(3)='0' and key(2)='0' and key(1)='1' and key(0)='0') then value_counter <= value_counter + "1"; elsif (key(3)='0' and key(2)='0' and key(1)='0' and key(0)='1') then value_counter <= value_counter - "1"; elsif (key(3)='1' and key(2)='0' and key(1)='0' and key(0)='0') then register_counter<= register_counter + "1"; elsif (key(3)='0' and key(2)='1' and key(1)='0' and key(0)='0') then register_counter<= register_counter - "1"; end if; end if; end process; end architecture up_and_down; I get the error `Error (10577): VHDL error at DE2_TOP.vhd(312): actual port "a" of mode "in" cannot be associated with formal port "register_counter" of mode "out"`on the line indicated above. It is obvious this is not how I would go about doing what I want to do. Can someone shed some light on this?링크가 복사됨
4 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Look at the next line after the one where the error is and you will see what is wrong.
You can not assign a input signal (in this case "a" from entity "raminfr" is a input) to a component where the signal is defined as output ("register_counter" from component "lab1" is a output and not a input).- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Look at the next line after the one where the error is and you will see what is wrong. You can not assign a input signal (in this case "a" from entity "raminfr" is a input) to a component where the signal is defined as output ("register_counter" from component "lab1" is a output and not a input). --- Quote End --- Yes, I realize that, but I don't know how to get around it. Do you see what I'm trying to accomplish? How do I legally get the value of register_counter into my RAM entity?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
You can define a second address signal for the write access to the memory from your "lab1" component. This way you will generate a dual port memory where one port is used for the external and one for the internal memory access.
Or use a MUX to multiplex the external and internal address signals. I also recommend to assign "clk" and "key" to your "lab1" component instantiation.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- You can define a second address signal for the write access to the memory from your "lab1" component. This way you will generate a dual port memory where one port is used for the external and one for the internal memory access. Or use a MUX to multiplex the external and internal address signals. I also recommend to assign "clk" and "key" to your "lab1" component instantiation. --- Quote End --- I don't want to be a pest, but I'm a little bit new to VHDL - could you possibly elaborate on what you mean with a few lines of code?
