17260 Discussions
VHDL - Writing a Value to Register
I have an FPGA (Cyclone II) with four push buttons - the two left most ones should cycle up and down the 16 registers, while the two right most ones should increment and decrement the value stored in this register. Here is my attempt at the code to do this:
entity raminfr is --inferring the RAM here
port (
clk : in std_logic;
we : in std_logic;
a : in unsigned(3 downto 0);
di : in unsigned(7 downto 0);
do : out unsigned(7 downto 0)
end raminfr;
architecture rtl of raminfr is
type ram_type is array (0 to 15) of unsigned(7 downto 0);
signal RAM : ram_type;
signal read_a : unsigned(3 downto 0);
begin
U1: entity work.lab1 port map ( --ERROR ON THIS LINE
register_counter => a,
value_counter => di
process (clk)
begin
if rising_edge(clk) then
if we = '1' then
RAM(to_integer(a)) <= di;
end if;
read_a <= a;
end if;
end process;
do <= RAM(to_integer(read_a));
end rtl;
--lab1 starts here
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity lab1 is
port(
clock : in std_logic;
key : in std_logic_vector(3 downto 0);
value_counter : out unsigned(7 downto 0) ; --value to be written to register
register_counter : out unsigned(3 downto 0) --register to write value to
end lab1;
architecture up_and_down of lab1 is --actual button logic here
begin
process(clock)
begin
if rising_edge(clock) then
if (key(3)='0' and key(2)='0' and key(1)='1' and key(0)='0') then
value_counter <= value_counter + "1";
elsif (key(3)='0' and key(2)='0' and key(1)='0' and key(0)='1') then
value_counter <= value_counter - "1";
elsif (key(3)='1' and key(2)='0' and key(1)='0' and key(0)='0') then
register_counter<= register_counter + "1";
elsif (key(3)='0' and key(2)='1' and key(1)='0' and key(0)='0') then
register_counter<= register_counter - "1";
end if;
end if;
end process;
end architecture up_and_down;
I get the error `Error (10577): VHDL error at DE2_TOP.vhd(312): actual port "a" of mode "in" cannot be associated with formal port "register_counter" of mode "out"`on the line indicated above. It is obvious this is not how I would go about doing what I want to do. Can someone shed some light on this?
Look at the next line after the one where the error is and you will see what is wrong.
You can not assign a input signal (in this case "a" from entity "raminfr" is a input) to a component where the signal is defined as output ("register_counter" from component "lab1" is a output and not a input).
--- Quote Start ---
--- Quote End ---
Yes, I realize that, but I don't know how to get around it. Do you see what I'm trying to accomplish? How do I legally get the value of register_counter into my RAM entity?
You can define a second address signal for the write access to the memory from your "lab1" component. This way you will generate a dual port memory where one port is used for the external and one for the internal memory access.
Or use a MUX to multiplex the external and internal address signals.
I also recommend to assign "clk" and "key" to your "lab1" component instantiation.
--- Quote Start ---
--- Quote End ---
I don't want to be a pest, but I'm a little bit new to VHDL - could you possibly elaborate on what you mean with a few lines of code?
