VHDL aggregate error
Hello I had errors that said , "Error (10514): VHDL aggregate error at gate.vhd(47): can't determine type of aggregate -- found 0 possible types"
What does it means ? Thank you
LIBRARY ieee;
USE ieee.std_logic_unsigned.ALL;
USE ieee.numeric_std.ALL;
USE ieee.std_logic_1164.ALL;
entity gate is
port(
clk : in std_logic;
reset : in std_logic;
gate_out : out std_logic
end gate;
architecture gate_a of gate is
--signal reset : STD_LOGIC := '0'; -- disabled reset; TODO move this signal to port
signal timer_haut : UNSIGNED(25 downto 0) := (others => '0');
signal timer_bas : UNSIGNED(25 downto 0) := (others => '0');
signal timer_tick : STD_LOGIC;
begin
process(clk)
begin
if rising_edge(clk) then
if (reset = '1') then
timer_haut <= (others => '0');
else
timer_haut <= timer_haut + 1;
end if;
end if;
end process;
process(clk)
begin
timer_bas <= (others => '0');
else
timer_bas <= timer_bas + 1;
end if;
end if;
end process;
timer_tick <= '1' when (timer_haut = to_unsigned(50 * 1000 * 1000), timer_us'length) else
'0' when (timer_bas = to_unsigned(60 * 1000 * 1000), timer_us'length);
end gate_a;
you've put the , in the correct place:
should be
(timer_bas = to_unsigned(60 * 1000 * 1000, timer_us'length) )
Thank you ! lol
