17268 Discussions
Error (10349): VHDL Association List error at mult16bit.vhd(41): formal "o" does not
entity mult16bit is
generic (
DATA_WIDTH : integer := 16
port(
a : in std_logic_vector(DATA_WIDTH-2 downto 0);
--PARAM
b : in std_logic_vector(15 downto 0);
--PARAM
c : out std_logic_vector((3*DATA_WIDTH)-1 downto 0)
end mult16bit;
architecture Behavioral of mult16bit is
signal right : std_logic_vector((DATA_WIDTH)+4-3 downto 0);
signal left : std_logic_vector((DATA_WIDTH)+4-3 downto 0);
signal left_shifted : std_logic_vector((2*DATA_WIDTH)-2 downto 0);
signal new_right : std_logic_vector((2*DATA_WIDTH)-2 downto 0);
begin
MULTIPLIER_right:entity work.mult8bit
port map(
a => a(7 downto 0),
b => b,
o => right
MULTIPLIER_left:entity work.mult8bit
port map(
a => a(15 downto 8),
b => b,
o => left
left_shifted <= left & "0000000" ;
left_shifted <= std_logic_vector("sll"(unsigned(left), 8));
new_right <= "00000000" & right;
c <= unsigned(new_right) + unsigned(left_shifted) ;
end Behavioral;
this is my code and i m getting this error please help me to solve this thanks
Error (10349): VHDL Association List error at mult16bit.vhd(41): formal "o" does not exist File: /mult16bit.vhd Line: 41
Shouldn't you be using c instead of o?
we cannot see the declaration of mult8bit, but I assume "o" does not exist as an output port from that entity.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library work;
use work.all;
entity mult16bit is
generic (
port(
a : in std_logic_vector(DATA_WIDTH-1 downto 0);
--PARAM
b : in std_logic_vector(7 downto 0);
--PARAM
c : out std_logic_vector((2*DATA_WIDTH)-1 downto 0)
end mult16bit;
signal right : std_logic_vector((DATA_WIDTH)+4-1 downto 0);
signal left : std_logic_vector((DATA_WIDTH)+4-1 downto 0);
signal left_shifted : std_logic_vector((2*DATA_WIDTH)-1 downto 0);
signal new_right : std_logic_vector((2*DATA_WIDTH)-1 downto 0);
begin
port map(
a => a(7 downto 0),
b => b,
c => right
port map(
b => b,
c => left
-- left_shifted <= std_logic_vector("sll"(unsigned(left), 8));
end Behavioral;
sir now i m getting this error please help me thanks
expression has 20 elements, but must have 16 elements File: /mult16bit.vhd Line: 41
expression has 16 elements, but must have 20 elements File: /mult16bit.vhd Line: 41
I still cannot see the declaration of mult8bit, but I assume the output (c) is 16 bits.
"Left" and "right" are 20 bits, hence the errors.
so either:
fix the length of left and right
only map the appropriate bits.
--- Quote Start ---
so either:
--- Quote End ---
thanks sir for your help.
