17255 Discussions
VHDL code for register, to use in a binary multiplication circuit
I wrote a piece a VHDL code for a register (to make a shift register circuit) in a binary multiplication circuit. Once I analyzed it in Quartus II several syntax errors were displayed.
This is my code:
ENTITY memory ISPORT (can_load, can_shift, can_ad, sb_input, ab_input, UserInput : IN BIT;
Out_Bit, Z : OUT BIT);
END memory;
ARCHITECTURE logic OF memory IS SIGNAL State: BIT := '0';
BEGIN
IF (can_load = '1') THEN
State <= UserInput;
ELSE
IF (can_ad = '1')
THEN Z <= State; --Z is the output that goes to the 4 bit adder
State <= ab_input;
END IF;
IF (can_shift = '1') THEN
Out_Bit <= State;
State <= sb_input;
END IF;
END IF;
END logic;
This are the error messages:
Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis Info: Version 14.0.0 Build 200 06/17/2014 SJ Web Edition Info: Processing started: Sun Oct 19 16:28:22 2014 Info: Version 14.0.0 Build 200 06/17/2014 SJ Web Edition Info: Processing started: Sun Oct 19 16:28:22 2014
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off memory -c memory
Warning (20028): Parallel compilation is not licensed and has been disabled
Error (10500): VHDL syntax error at memory.vhd(9) near text "IF"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at memory.vhd(9) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at memory.vhd(11) near text "ELSE"; expecting "end", or "(", or an identifier ("else" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at memory.vhd(12) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at memory.vhd(15) near text "IF"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
Error (10500): VHDL syntax error at memory.vhd(16) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at memory.vhd(19) near text "IF"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
Info (12021): Found 0 design units, including 0 entities, in source file memory.vhd
I have already checked several books for the correct syntax, and code examples and yet I cannot find where's my mistake.
I also tried to take away the parentheses in sections like this:
having something like this:
IF can_load = '1' THEN
but I ended up with most of the same syntax errors.
I'd appreciate any help to solve this issue. Thank you very much.
conditional assigment with "if" are only valid inside a process:
process( here write the sensitivity list
begin
if( ....
Anyway, your code doesn't look good. You are using vhdl like a C program.
When you put the code in a process, the code you have does not actually describe a register - you need a clock input. and then all the code needs to be wrapped inside:
if rising_edge(clk) then
--- Quote Start ---
--- Quote End ---
Thank you, I just did it and it did work :)
Thank you, I put it inside a clock process and it did work.
I am new to VHDL, so I would really appreciate if you could share some link to an example of a well written VHDL code. I know I do write as if I were making a C program, because I've only coded microcontrollers in C.
This book is highly recommended: http://www.amazon.co.uk/designers-guide-vhdl-systems-silicon/dp/0120887851/ref=sr_1_1?ie=utf8&qid=1413965590&sr=8-1&keywords=designers+guide+to+vhdl
but any good tutorial you can find on google should tell you how to code the basics.
--- Quote Start ---
--- Quote End ---
Thank you so much :)
