17255 Discussions
Verilog: Attempting to make a signal high for 5 clock cycles and then remain low
frank2597
I am trying to make the signal called ld_tx_data_scope a value of 1 after the first 5 positive edges and remain high for 5 positive edges and then have it go low and stay low. However, simulating the Verilog code provides this output for ld_tx_data_scope:
As, you can see above the signal remains low.
The Verilog code is shown below:
module test(
clk_50,
ld_tx_data_scope
input clk_50;
reg ld_tx_data;
output reg ld_tx_data_scope;
reg tx_enable;
reg [7:0] my_tx_data;
reg rx_enable;
reg [16:0] ld_tx_counter_debug;
reg ld_tx_toggle;
reg [16:0] ld_tx_data_scope_uptime;
initial
    begin
    tx_enable <= 1;
    rx_enable <= 0;
    my_tx_data <= 8'b01010101;
    end
always @* begin
    ld_tx_data_scope = ld_tx_data;
end
always@(posedge clk_50)
 begin
 ld_tx_counter_debug <= ld_tx_counter_debug + 1;
 //rx_counter <= rx_counter + 1;
 if(ld_tx_counter_debug == 5 && ld_tx_toggle == 0) //5000
 begin
    ld_tx_counter_debug <= 0;
    ld_tx_data <= 1;
    ld_tx_toggle = 1;
 end
 if (ld_tx_toggle == 1)
 begin
 ld_tx_data_scope_uptime = ld_tx_data_scope_uptime + 1;
    if (ld_tx_data_scope_uptime == 5)//100
    begin
    ld_tx_data <= 0;
    ld_tx_data_scope_uptime = 0;
    end
 end
end
endmodule
I have also attached the project files. Any help is appreciated. Thanks
ShengN_Intel
Because you haven't initialize the reg ld_tx_toggle. If you had initialized like this reg ld_tx_toggle = 1'b0; You'll get correct simulation like pic below:
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
roeekalinsky
Valued Contributor I
Hi Frank,
There are numerous problems in your Verilog code, but this is not an appropriate place for this query.  This forum is meant for discussions on issues pertaining to Quartus software.  The problems you're having are with basic Verilog programming, having nothing to do with Quartus in particular.  I'd suggest you begin with a good primer course or book to learn the fundamentals of RTL design and the Verilog language.
-Roee
_AK6DN_
Valued Contributor II
Indeed. Asking your questions in this online forum ...
https://www.eevblog.com/forum/fpga/
... might get you much better results.
ShengN_Intel
Sheng
ShengN_Intel
Any further update or concern?
Sheng
