17249 Discussions
Verilog HDL CODE Help!
Cancelled:cry::cry::cry::cool:
These are basic exercises.
Looks like an homework? :-)
Spend at least ten minutes looking into an HDL book and we'll see
The UD counter looks ok.
The MUX uses a command I don't know.
--- Quote Start ---
assign mux_out = (sel)?SOURCE0_IH:SOURCE1_IH:SOURCE2_IH:SOURCE3_IH: SOURCE4_IH:SOURCE5_IH:SOURCE6_IH:SOURCE7_IH;
--- Quote End ---
I only use the conditional operator (?) as a ternary operator. Don't know if can be used in this sense.
I would use a case statement:
--- Quote Start ---
reg mux_out;
always @(sel,SOURCE0_IH,SOURCE1_IH, etc.)
case (sel)
3'b000: mux_out = SOURCE0_IH;
3'b001: mux_out = SOURCE1_IH;
default: mux_out = 1'b0;
endcase
--- Quote End ---
You have to define sel as a bit vector. Now it's a single bit.
sel;
Then the mux code should work.
It has been a nice idea to extend the conditional operator to multiple alternatives in your previous example. Unfortunately the Verilog standard doesn't know it.
sel is an input, not of the reg type.
A simple bit signal can only display values 0 and 1.
