17268 Discussions
Verilog issue with case & assign statement
I defined an assign and case statement in my code as following:
// NOT into a process
assign cf_data = cf_we_n ? cf_data_in : cf_data_out;
// State into a case statement, into a process.
CM_WR_DATA: begin
cf_we_n = 1'b0;
i_wr = i_wr + 1;
n_pin_control = CM_WR_WAIT;
end
It seems pretty short and easy, but I got an issue : my state CM_WR_DATA is done two times instead of one time, so my integer i_wr is incremented by 2. It is due to the assign statement. In fact, if I comment the assign statement, it works. By the same way, if I comment the cf_we_n, it works too. cf_data is not in the sensitive list of the process involved. I have only one state machine, so there isn't any conflicts.
So I tried to create a case state in addition:
CM_WR_DATA: begin
cf_we_n = 1'b0;
n_pin_control = CM_WR_ADDITIONNAL;
end
CM_WR_ADDITIONNAL: begin
i_wr = i_wr + 1;
end
It doesn't fix my problem, i_wr is still incremented by 2.
Does sb have any ideas ?
Thanks !
I doubt, if the problem can be found without knowing the complete process code. But in any case, I won't use non-blocking assignments in the process. It's, as a popular paper says, a coding style that kills.
