17258 Discussions
Wait Statement error in VHDL
I read on bit adder in VHTL in Quartus II 9.1 from this site:
http://esd.cs.ucr.edu/labs/adder/add_tst.vhd
first according guide I add and compile 1 bit adder,it works correctly
-- Simulation Tutorial -- 1-bit Adder -- This is just to make a reference to some common things needed. LIBRARY IEEE; use IEEE.STD_LOGIC_1164.ALL; -- We declare the 1-bit adder with the inputs and outputs -- shown inside the port(). -- This will add two bits together(x,y), with a carry in(cin) and -- output the sum(sum) and a carry out(cout). entity BIT_ADDER is port( a, b, cin : in STD_LOGIC; sum, cout : out STD_LOGIC ); end BIT_ADDER; -- This describes the functionality of the 1-BIT adder. architecture BHV of BIT_ADDER is begin -- Calculate the sum of the 1-BIT adder. sum <= (not a and not b and cin) or (not a and b and not cin) or (a and not b and not cin) or (a and b and cin); -- Calculates the carry out of the 1-BIT adder. cout <= (not a and b and cin) or (a and not b and cin) or (a and b and not cin) or (a and b and cin); end BHV;
when I compile it it works right.
after that I add other VHTL to test that.
this is testbench of 1 bit adder:
-- ENGR 10 VHDL Lab -- 1-bit Adder Testbench -- A testbench is used to rigorously tests a design that you have made. -- The output of the testbench should allow the designer to see if -- the design worked. The testbench should also report where the testbench -- failed. -- This is just to make a reference to some common things needed. LIBRARY IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Decare a testbench. Notice that the testbench does not have any -- input or output ports. entity TEST_ADD is end TEST_ADD; -- Describes the functionality of the tesbench. architecture TEST of TEST_ADD is -- The object that we wish to test is declared as a component of -- the test bench. Its functionality has already been described elsewhere. -- This simply describes what the object's inputs and outputs are, it -- does not actually create the object. component BIT_ADDER port( a, b, cin : in STD_LOGIC; sum, cout : out STD_LOGIC ); end component; -- Specifies which description of the adder you will use. for U1: BIT_ADDER use entity WORK.BIT_ADDER(BHV); -- Create a set of signals which will be associated with both the inputs -- and outputs of the component that we wish to test. signal A_s, B_s : STD_LOGIC; signal CIN_s : STD_LOGIC; signal SUM_s : STD_LOGIC; signal COUT_s : STD_LOGIC; -- This is where the testbench for the BIT_ADDER actually begins. begin -- Create a 1-bit adder in the testbench. -- The signals specified above are mapped to their appropriate -- roles in the 1-bit adder which we have created. U1: BIT_ADDER port map (A_s, B_s, CIN_s, SUM_s, COUT_s); -- The process is where the actual testing is done. process begin -- We are now going to set the inputs of the adder and test -- the outputs to verify the functionality of our 1-bit adder. -- Case 0 : 0+0 with carry in of 0. -- Set the signals for the inputs. A_s <= '0'; B_s <= '0'; CIN_s <= '0'; -- Wait a short amount of time and then check to see if the -- outputs are what they should be. If not, then report an error -- so that we will know there is a problem. wait for 10 ns; assert ( SUM_s = '0' ) report "Failed Case 0 - SUM" severity error; assert ( COUT_s = '0' ) report "Failed Case 0 - COUT" severity error; wait for 40 ns; -- Carry out the same process outlined above for the other 7 cases. -- Case 1 : 0+0 with carry in of 1. A_s <= '0'; B_s <= '0'; CIN_s <= '1'; wait for 10 ns; assert ( SUM_s = '1' ) report "Failed Case 1 - SUM" severity error; assert ( COUT_s = '0' ) report "Failed Case 1 - COUT" severity error; wait for 40 ns; -- Case 2 : 0+1 with carry in of 0. A_s <= '0'; B_s <= '1'; CIN_s <= '0'; wait for 10 ns; assert ( SUM_s = '1' ) report "Failed Case 2 - SUM" severity error; assert ( COUT_s = '0' ) report "Failed Case 2 - COUT" severity error; wait for 40 ns; -- Case 3 : 0+1 with carry in of 1. A_s <= '0'; B_s <= '1'; CIN_s <= '1'; wait for 10 ns; assert ( SUM_s = '0' ) report "Failed Case 3 - SUM" severity error; assert ( COUT_s = '1' ) report "Failed Case 3 - COUT" severity error; wait for 40 ns; -- Case 4 : 1+0 with carry in of 0. A_s <= '1'; B_s <= '0'; CIN_s <= '0'; wait for 10 ns; assert ( SUM_s = '1' ) report "Failed Case 4 - SUM" severity error; assert ( COUT_s = '0' ) report "Failed Case 4 - COUT" severity error; wait for 40 ns; -- Case 5 : 1+0 with carry in of 1. A_s <= '1'; B_s <= '0'; CIN_s <= '1'; wait for 10 ns; assert ( SUM_s = '0' ) report "Failed Case 5 - SUM" severity error; assert ( COUT_s = '1' ) report "Failed Case 5 - COUT" severity error; wait for 40 ns; -- Case 6 : 1+1 with carry in of 0. A_s <= '1'; B_s <= '1'; CIN_s <= '0'; wait for 10 ns; assert ( SUM_s = '0' ) report "Failed Case 6 - SUM" severity error; assert ( COUT_s = '1' ) report "Failed Case 6 - COUT" severity error; wait for 40 ns; -- Case 7 : 1+1 with carry in of 1. A_s <= '1'; B_s <= '1'; CIN_s <= '1'; wait for 10 ns; assert ( SUM_s = '1' ) report "Failed Case 7 - SUM" severity error; assert ( COUT_s = '1' ) report "Failed Case 7 - COUT" severity error; wait for 40 ns; end process; END TEST;
but this error appear :
Error (10533): VHDL Wait Statement error at add_test.vhd(65): Wait Statement must contain condition clause with UNTIL keyword
First - you need to repost the code with some carrige returns!!
it sounds like you tried to compile a testbench in quartus. You cant do that. You need to run it in a simulator
