17268 Discussions
Warning: No paths found for timing analysis
I'm writing a spi module,just a receiver. Few lines,but many warnings.
The total logic elements is 0%.
Can an get a answer about how to result the problem?
Code:
module spi (input clk,
input cs,
input sdi,
output reg getdata,
output reg [7:0] recbuf
reg stsig = 0;
reg [3:0] reccount = 7;
always @(cs)
if(sdi) stsig = 0;
else stsig = 1;
always @(posedge clk)
begin
if(stsig && reccount<8)
begin
recbuf[reccount] = sdi;
reccount = reccount - 1;
end
else
begin
reccount = 7;
getdata = 1;
end
end
endmodule
Warnings:
Warning: Output pins are stuck at VCC or GND
Warning: Design contains 3 input pin(s) that do not drive logic
Warning: No exact pin location assignment(s) for 12 pins of 12 total pins
Warning: Following 9 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
getdata is obviously assigned 1 once and for all so it is stuck to VCC.
recbuf[] is assigned sdi when stsig is true yet when true sdi is zero so recbuf stays zero.
But sdi can be 1 or 0.So recbuf will be 1 or 0 according sdi,won't they?:confused:
when sdi is 1, stsig becomes zero
when sdi is 0, stsig becomes one and if condition executes to assign to recbuf the zero sdi.
if sdi becomes 1 then stsid is zero and else condition executes doing nothing to recbuf.
so rebuf stays zero.
however, you might have point there because sdi and stsig change on the change of cs. So we need to look at that ...??
Yes.I just want to say it .
just simulated it in modelsim, seems working.
Are you sure you are synthesizing the right files
Yes.No error occur when I compile it,but Total logic elements is 0%
I don't have quartus handy at the moment but I am a bit puzzled now.
I know you are creating a latch at cs but I expect warning of latches rather than zero logic.
You may try avoid the latch by inserting your cs statemet on the clock edge just like other signals.
always @ (posedge clk)
if cs...
assuming it does not affect your functionality
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 9.0 Build 132 02/25/2009 SJ Full Version
Info: Processing started: Sat Jul 30 23:59:01 2011
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off spi -c spi
Info: Found 1 design units, including 1 entities, in source file spi.v
Info: Found entity 1: spi
Yes, it does not affect my functionality.But it will increase the time the logic elements judging them.
In fact ,I am just a beginer leaning it for our Electronic Design Competition.If I can't solve the problem maybe I will get a spi communication module from our instructor.And I know FSM can work well from a book I read yesterday,but I don't want to use it while I'm leaning.
Thank you very much for your suggestion,I will try it.
There might issue of tools here. While modelsim acepts your code it could be quartud thinks that stsig is assigned 0 and recbuf is assigned 7. you might better use init for that instead
But
always @(cs)
if(sdi) stsig = 0;
else stsig = 1;
is used to identify a start of a data receiving and datas will be delivered many times however initial just run once.
It's too late now,I'll go sleeping.
Thank you for your advise.Enjoy a good afternoon!
