17268 Discussions
Warning: pcie_a10_hip_0.phy_g2x4
morrison
I get the following warning in Platform Designer when generating the HDL for the PCIe interface with the Arria 10.
Warning: pcie_a10_hip_0.phy_g2x4: The value of parameter hssi_rx_pld_pcs_interface_hd_chnl_hrdrstctl_en cannot be automatically resolved. Valid values are: enable disable.
Quartus Prime 20.1.1 Build 720 11/11/2020 SJ Standard Edition Patches Installed: 1.02std,1.09std
Wincent_Altera
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate and get back to you soon. Thanks for your patience.
Wei Chuan
Wincent_Altera
Can you try it at Quartus Standard v21.2 above and see if you are seeing the same error ?
Wei Chuan
morrison
Hi Thanks a lot,
It has not been tried, but we are looking to remove the warning without updating the version open some information about it.
Wincent_Altera
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
morrison
I have part of the log files it would help to review it.
Wincent_Altera
Do you able to try it at suggested quartus version ?
Wincent_Intel
morrison
I was able to duplicate this in Quartus 22.1std.1 Build 917
Attached is the Platform Designer system.
Wincent_Altera
I looked into this warning and confirmed that it can be safely ignored. Please let me know if this answers your question or if you have any questions or concern around this.
Wincent_Intel
Wincent_Altera
Wincent_Intel
Wincent_Altera
Wincent_Intel
Wincent_Altera
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
