17266 Discussions
Waveform Simulation -> Init Burried
Contributeur émérite II
1 835 Visites
Hi!
I am using the waveform editor in Quartus II. Everything works fine, I can add IN and OUT nodes and I can see the simulation results. But now I need to set some BURRIED nodes to specific values. I can do this in the waveform editor but this doesn't affect the simulation results. It seems that the simulation always uses the init values for BURRIED nodes.
Is there a way to set the BURRIED nodes to specific values for the simulation?
Andre
0 Compliments
5 Réponses
803 Visites
--- Quote Start ---
Hi!
Andre
--- Quote End ---
Hi Andre,
as far as I know it is not possible to force internal node with the waveform editor.
Kind regards
GPK
0 Compliments
803 Visites
Hi!
Thanks for your reply!
Andre
0 Compliments
803 Visites
Is possible to set intial value?
Bye
0 Compliments
803 Visites
I read somewhere that the Altera devices can't init to values <> 0.
If initial values <> 0 are used the quartus compiler initialize them to 0 and uses inverters on both sides of the register. And it seems that the simulation tool won't work as expected anymore with this registers.
I am initializing and the first input clock now. This works fine for me.
Thank you!
0 Compliments
803 Visites
--- Quote Start ---
Bye
--- Quote End ---
as far as I know, it is not possible.
Kind regards
GPK
0 Compliments
Répondre
