Hi!
I am using the waveform editor in Quartus II. Everything works fine, I can add IN and OUT nodes and I can see the simulation results. But now I need to set some BURRIED nodes to specific values. I can do this in the waveform editor but this doesn't affect the simulation results. It seems that the simulation always uses the init values for BURRIED nodes. Is there a way to set the BURRIED nodes to specific values for the simulation? Regards, AndreLink Copied
--- Quote Start --- Hi! I am using the waveform editor in Quartus II. Everything works fine, I can add IN and OUT nodes and I can see the simulation results. But now I need to set some BURRIED nodes to specific values. I can do this in the waveform editor but this doesn't affect the simulation results. It seems that the simulation always uses the init values for BURRIED nodes. Is there a way to set the BURRIED nodes to specific values for the simulation? Regards, Andre --- Quote End --- Hi Andre, as far as I know it is not possible to force internal node with the waveform editor. Kind regards GPK
Hi!
Thanks for your reply! Regards Andre- Mark as New
Is possible to set intial value?
Bye- Mark as New
I read somewhere that the Altera devices can't init to values <> 0.
If initial values <> 0 are used the quartus compiler initialize them to 0 and uses inverters on both sides of the register. And it seems that the simulation tool won't work as expected anymore with this registers. I am initializing and the first input clock now. This works fine for me. Thank you!- Mark as New
--- Quote Start --- Is possible to set intial value? Bye --- Quote End --- Hi, as far as I know, it is not possible. Kind regards GPK
