17267 Discussions
What exactly is essence of "Library Mapping" in ModelSim, map to what and why?
When do we map libraries and why, when we create a Quartus II project why do we still need to create a new library?
I am completely new to the whole ModelSim thing and am confused about this issue at present.
--- Quote Start ---
--- Quote End ---
VHDL defines the use of libraries for reuseable code. If you've ever coded in C, the analogy is that when you want to reuse C-code, you create a header file with the functions to re-use in other code, and a C-file (or multiple files) containing the implementations, that code can then be compiled into a static or dynamic library for linking against your application code. In Modelsim, the compiled library exists within a library folder, and the library can be re-used by multiple designs. Quartus does not respect libraries, and just compiles everything into a common internal library (Quartus will accept library syntax, but it doesn't really do anything useful with it).
For example, when using Modelsim, the lines
library ieee; use ieee.std_logic_1164.all;
allow you to use the std_logic_vector type. You can create create your own library and build code into it via commands like
vlib mylib vmap mylib /mylib vcom -work mylib mycomponent_pkg.vhd vcom -work mylib mycomponent.vhd
where the mycomponent_pkg.vhd file contains a package with the component declaration (analogous to a .h header file when coding in C), and mycomponent.vhd contains the implementation (analogous to a .c file).
In your top-level design (analogous to your c application code), you can then access your component via
library mylib; use mylib.mycomponent_pkg.all;
and then create an instance of mycomponent.
Bottom-line is that its an organizational feature implemented in VHDL, ignored in Verilog, and (I think) picked up in SystemVerilog.
Cheers,
Dave
I think you are slightly confusing packages and libraries. Packages and design unit/entities exist inside libraries. VHDL defines logical libraries, and a tool maps a logical name in the language to a physical place in an OS filesystem. VHDL allows you to compile different architectures (like RTL-level and Gate-level) of the same unit into different logical libraries. So if you have 5 instances of the same unit in one design, you can have 4 of them use the RTL version and the other use the gate-level for better simulation performance. You can also choose different architectures to tweak synthesis results. Modelsim lets you do this for Verilog designs as well, but it was outside of the scope of the language until SystemVerilog came around.
