please help me.
I'm a newbie in this field, i have a problem and i hope that you all can help me.
i wanted to add in countdown timer into the music box that shown at fpga4fun but i have no idea on how to do the coding for the countdown timer, so i need your help. :(
i hope that the countdown timer is in VHDL code or you all can give me the VHDL coding and i'll try to change the music box verilog code so that i can add in the VHDL code.
The countdown timer that i want is when i turn on the music box it will countdown 5 second, after countdown it will start to play music.
thanks you very much for your help :)
Are you using a dev. board? What is the frequency of the fpga clock? The timer is based on the clock period. The code looks like:
entity....
architecture arch of ent_name is
begin
process(rst, clk)
begin
if(rst='1') then
cont_reg <= ( others=>'0');
elsif(clk'event and clk='1') else
cont_reg <= cont_prox;
end if;
end process;
cont_prox <= cont_reg + 1 when ( cont_reg < timeout ) else
cont_reg;
start <= '0' when ( cont_reg < timeout ) else
'1';
end architecture arch;
The signal "start" goes up to '1' when expires the timer. you enable the circuit with this signal. The constant timeout depends of clock period.
