17268 Discussions
What is usage of "generate" in Verilog?
I am confused by the usage of "generate" in Verilog. I checked it online, find some demo codes like:
genvar index;
generate
for (index= 0;index < 64;index = index+1) begin : dq_delay
WireDelay#
.Delay_g (TPROP_PCB_DATA),
.Delay_rd (TPROP_PCB_DATA_RD),
.ERR_INSERT ("OFF")
u_delay_dq
.A (ddr3_dq_fpga[index]),
.B (ddr3_dq_sdram[index]),
.reset (~i_rst_p),
.phy_init_done (init_calib_complete)
end
endgenerate
But what is the difference between using "generate" and only use "For" without "generate"? If I wrote the above codes as:
WireDelay#
.ERR_INSERT ("OFF")
u_delay_dq
.reset (~i_rst_p),
end
No "generate", what is the difference?
You still need the genvar index; statement in either situation.
Verilog 2005 made the generate/endgenerate keywords optional. Since the for loop appears outside of a procedural context, the extra keywords are unnecessary. The compiler is able to figure out that a for/if/case statement in a module context outside a procedural context is a generate block.
Verilog is a language full of implicit defaults. But sometimes it is better to document your intent by putting the extra keywords in there.
--- Quote Start ---
--- Quote End ---
Thanks, dave_59. So that means two codes I wrote are same in Verilog 2005, right?
Another question, you mentioned "for/if/case statement in a module context outside a procedural context is a generate block." Do you mean "if" or "case" out of "always"? I have never see that.
Yes, those construct have always been available together with for as a generate construct. See LRM 27.5 conditional generate constructs.
--- Quote Start ---
--- Quote End ---
Thanks, dave_59. I am still confused by this. Could you please give an example that "if/case" out of "always"? They must work with generate together, right? I mean if "if/case" is out of "always", "generate" can't be neglected like "for" statement. right?
There are examples in the LRM section I mentioned, particularity a for nested inside a case generate. Don't have a copy of the LRM? get one (go.mentor.com/get-1800)!
--- Quote Start ---
--- Quote End ---
Thanks. I should get one. Do you know what is the latest version?
The one in the link I just posted.
--- Quote Start ---
--- Quote End ---
Thanks. But where is the link? I did not see it.
Put your cursor over the words "get one"
Thanks very much.
