17250 Discussions
What would happen if VCCPD is less than VCCIO?
AThai8
Hi, I am using the Cyclone V GT. What would happen if my VCCPD is 2.5V and VCCIO is 3.3V for the same bank?
YuanLi_S_Intel
Hi AN Thai,
There is no problem as both power rail are different. Supplying different VCCPD and VCCIO is depending on the I/O standard that you are going to use. You may refer to device user guide for more information about it.
Thank You.
AThai8
Thank you for the response.
Please allow me to elaborate a bit further. Based on the data sheet VCCPD must be 3.3V when VCCIO is 3.3V and must be 2.5V when VCCIO is less than or equal to 2.5V. I have an adjustable VCCIO between 1.2V and 3.3V, my question is as my VCCIO varies, can VCCPD stays at 2.5V? Or should I switch VCCPD between 2.5V and 3.3V as VCCIO changes?
Thank you.
YuanLi_S_Intel
Hi AN Thai,
First of all, the VCCIO shouldnt be changing. It must be fixed at all the time. Thus, it is not appropriate for the method.
Thank You
