17267 Discussions
Where I can find document for PCI Express IP in Qsys?
I want to use PCI Express IP in Qsys for my next project. When I click "document" (http://www.altera.com/products/ip/iup/pci-express/m-alt-pcie8.html) link from qsys, it is showing "the page is not longer available". Is there any method by which I can get this document?
http://www.alteraforum.com/forum/attachment.php?attachmentid=10977&stc=1
NB: I am using Quartus II 11.0.
ip compiler for pci express - user guide (https://www.altera.com/literature/ug/ug_pci_express.pdf
Cheers,
Alex
I went through that document, but in that Quartus II 14.0 is considered as default ISE. But I am using Quartus II 11.0 in which I am not able to find IP Catalog (as per Page 23).
The IP catalog was introduced in 14.0. Prior to that it was the MegaWizard manager.
Under 'Tools', select 'MegaWizard Plug-In Manager'. Select 'Create a new...' and click 'Next'.
Type 'pci' into the search box. It'll automatically filter all relevant IP. Under there you'll see the PCI Express IP you're after.
Cheers,
Alex
Thanks a lot.
--- Quote Start ---
--- Quote End ---
By the way, probably you could also highlight the document link bug in Qsys to Altera for fixes.
