17241 Discussions
Who wins VERILOG_MACRO.qsf or `define.v?
I have a design which `includes a header file which has `defines for default mode, say:`define ASIC_VERSION 32'h00000001
I have an "override" in my .qsf to specify the FPGA build, say:set_global_assignment -name VERILOG_MACRO "ASIC_REVISION=32'h12345678"
However, when I map I get this warning:Warning (10886): Verilog HDL macro warning at ...defines.v(line): overriding existing definition for macro "ASIC_VERSION",
The `include file is overriding the .qsf! This is precisely the opposite of my intention. Is there any modifier to make sure that the .qsf file wins?
Thanks, Tom
Turns out it is load order - just like Verilog. You have to place your VERILOG_MACROs after your VERILOG_FILEs for it to win. ~Tom
I declared victory too soon - seems to fail randomly, irregardless of load-order.
How about:
`ifndef ASIC_VERSION `define ASIC_VERSION 32'h00000001 `endif
will define ASIC_VERSION only if it is not currently defined (by the .qsf file)
( replaced `ifdef ... `else with `ifndef )
Tried that - it did not work. I tried both load orders - fails same.
Did you modify the definition in the include file to surround it with the `ifndef ... `endif lines?
What is the failure you are seeing?
I did indeed try the ifndef guard around the Verilog `defines - fails same regardless of load order.
Failure is the Warning (10886) cited above and the fact that I want the .qsf VERILOG_MACRO definitions to win - not the Verilog.
Strangely, in the .flow.rpt it shows the definitions I want. I get the warnings and then in the actual implementation I see that Verilog won out.
Update: --verilog_macro= on quartus_map command-line fails same.
