17258 Discussões
Why I cannot see the my state machine in the statemachine viewer?
Colaborador honorário II
2.316 Visualizações
Hi all,
I'm new in FPGA and Quartus EDA tools. I tried to design a simple state machine with the verilog code. It can be simulated successfully, but I don't think it was actually recognized as a State Machine because it is not shown in the statemachine viewer.
Is there any protocols I should follow while I am coding so that I can view the state machine in the viewer?
Thanks in advance.
My codes:
module statemachine(Y,reset,clock,X); // Input Port(s) input Y; input reset; input clock; // Output Port(s) output X; reg state,nextstate; reg X; parameter state0=0; parameter state1=1; always@(Y,state) begin if(state==state0) X=0; else if(state==state1) X=1; if(state==state0) if(~Y) nextstate=state1; if(state==state1) if(Y) nextstate=state0; end always@(posedge clock ,negedge reset) begin if(~reset) state<=state0; else state<=nextstate; end // Additional Module Item(s) endmodule
1 Responder
1.514 Visualizações
The state-machine only has two states and synthesis reduced it to a single register. You can see this single register in the RTL viewer (will have 'state' in its reference)
Try adding a third state, it will then show up as a state machine.
Responder
