17259 Discussions
moving from one version to another version of quartus quartus
Hi everyone,
Can I move my project from one version to a newer version of quartus without any problems?
Yes, but you should do a backup copy first, just in case.
I use multiple versions (different Quartus projects on different directories use the same source files via relative paths). It works great especially because I can compare results between the versions and I can easily go back when I find a regression.
I move a lot of project from 9.0 to 10.1 and from 10sp1 to 10.1 without problems.
i hope the same for you:))
Ale
What about SOPC Builder, Nios II , IP... ?
