17186 Discussions
Why can't the USB Blaster I&II drivers for cyclone 10 GX dev kit be installed on Windows 10 using Quartus Pro 19.1?
JZHUO3
Driver from Pro 19.1 package could not be installed. Downloaded patch from Pro 18.2: link could not be recognized instead.
Vicky1
Could you please check the below solution from knowledge database,
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-usb-blaster-ii-not-work-when-using-intel--quartus---.html
First install the standalone Quartus prime programmer v19.1 before installing the patch 0.03.
please let me know, how it works to you.
Vicky
JZHUO3
I have downloaded Intel® Quartus® Prime Pro Edition software version 19.1. The patch 0.03 doesn't work. Still encounter the same error for USB driver.
Would you suggest me to roll back in previous versions of Quartus Prime Pro?
Jingwei
Vicky1
Hi Jingwei,
No need to roll back to previous version since this patch is for fix the another issue.
Could you please try to update the drivers again using links below?
https://www.intel.com/content/www/us/en/programmable/documentation/iga1446847781805.html#iga1447182606816
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/drivers/dri-index.html
Vicky
JZHUO3
Thank you for your help. Anyway, I have downloaded the 18.2 programming tools and installed the USB blaster driver.
Jingwei
