17268 Discussions
Why the quotient always high resistance state when using the lpm_div
Hi, all,
i have a question on using the lpm_div, and added "lpm" lib to project, but the quotient always high resistance state.
Here is verilog file generated by "MegaWizard Plug-In Manager" tool.
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module LPM_DIV (
clken,
clock,
denom,
numer,
quotient,
remain);
input clken;
input clock;
input [16:0] denom;
input [51:0] numer;
output [51:0] quotient;
output [16:0] remain;
wire [16:0] sub_wire0;
wire [51:0] sub_wire1;
wire [16:0] remain = sub_wire0[16:0];
wire [51:0] quotient = sub_wire1[51:0];
lpm_divide LPM_DIVIDE_component (
.clock (clock),
.clken (clken),
.denom (denom),
.numer (numer),
.remain (sub_wire0),
.quotient (sub_wire1),
.aclr (1'b0));
defparam
LPM_DIVIDE_component.lpm_drepresentation = "UNSIGNED",
LPM_DIVIDE_component.lpm_hint = "LPM_REMAINDERPOSITIVE=TRUE",
LPM_DIVIDE_component.lpm_nrepresentation = "SIGNED",
LPM_DIVIDE_component.lpm_pipeline = 1,
LPM_DIVIDE_component.lpm_type = "LPM_DIVIDE",
LPM_DIVIDE_component.lpm_widthd = 17,
LPM_DIVIDE_component.lpm_widthn = 52;
endmodule
Then, i have programmed "Testbench" file to test lpm_div module, code is as following.//file name:LPM_DIV_tb.sv
`timescale 1ns/1ns
module LPM_DIV_tb;
reg clk = 0;
reg signed[51:0] numer = 0;
reg [16:0] denom = 0;
wire signed[51:0] quotient;
wire [16:0] remain;
wire clken;
wire clock;
always# 25ns clk = ~clk;
assign clock = clk;
always @(posedge clk)
begin
denom = denom + 1;
numer = numer + numer + denom;
end
assign clken = (denom >= 5);
LPM_DIV LPM_DIV(
.clken(clken),
.clock(clock),
.denom(denom),
.numer(numer),
.quotient(quotient),
.remain(remain));
endmodule
The result simulated by software "Questa Sim" is as following.
https://alteraforum.com/forum/attachment.php?attachmentid=14102&stc=1
