17253 Discussions
Why the type converter does not work ?
In my design I need to do is convert a std_logic_vector signal to the integer signal for array index. Then I do following:
use IEEE.NUMERIC_STD.ALL;
generic
C_SLV_ADWIDTH : integer := 6; -- This width is actual address width
constant C_NUM_REG : integer := 2 ** C_SLV_ADWIDTH;
signal slv_addr : std_logic_vector(C_SLV_ADWIDTH-1 downto 0);
signal slv_addr_integer : integer range 0 to C_NUM_REG;
slv_addr_integer <= to_Integer(slv_addr); -- this convert data type std_logic_vector to integer
But I get errors, why converter does not work?
Thanks in advance.
--- Quote Start ---
generic
Thanks in advance.
--- Quote End ---
to_integer(unsigned(x)); or
to_integer(signed(x));
The choice is yours. I think you want the first
Thanks very much, kaz. Yes, I want the first. I try what you suggested and it works.
--- Quote Start ---
--- Quote End ---
Great. Now it is your turn to explain to te forum why you need to cast unsigned (or signed) for std_logic.
I define an new type which is an array:
type array_reg is array (C_NUM_REG-1 downto 0) of std_logic_vector (C_SLV_DWIDTH-1 downto 0);
Then I declare a signal:
signal slv_reg : array_reg;
slv_reg will be used as a group of registers whose number will be small, like 32, 64. Then I want to use input signal "slv_addr" as the address to reach the register. So I try to convert it to "slv_addr_integer " then use it as:
a<=slv_reg(slv_addr_integer);
