17255 Discussions
all of a sudden ...Error: Compiler Error, not able to generate hardware
Hi, now I got a problem and don't know where to look at....
It says:
here are some details..please have a look, and tell me what to do or where to look at...
Terasic DE5Net OpenCL BSP 16.1 / 8 Core 16GB Host,Windows 10 x64
I can't combile my OpenCL.cl until end,
Hardware, Software, Drivers ans Path Variables ...seems ok...but you never know
I could need some advice an any clue :)
hello_world and vector_add comiled OK
my first own hello world worked fine
E:\altera\OpenCL>aoc --list-boards Board list: de5net_a7
E:\altera\OpenCL>aocl diagnose acl0 aocl diagnose: Running diagnostic from E:\altera\16.1\hld\board\de5net16.1/windows64/libexec Verified that the kernel mode driver is installed on the host machine. Using platform: Altera SDK for OpenCL Using Device with name: de5net_a7 : Terasic's Preferred Board Using Device from vendor: Terasic Corporation clGetDeviceInfo CL_DEVICE_GLOBAL_MEM_SIZE = 4294967296 clGetDeviceInfo CL_DEVICE_MAX_MEM_ALLOC_SIZE = 4293918720 Memory consumed for internal use = 1048576 Actual maximum buffer size = 4293918720 bytes Writing 4095 MB to global memory ... Write speed: 1281.97 MB/s Reading and verifying 4095 MB from global memory ... Read speed: 1440.19 MB/s Successfully wrote and readback 4095 MB buffer Transferring 8192 KBs in 16 512 KB blocks ... 882.76 MB/s Transferring 8192 KBs in 8 1024 KB blocks ... 1010.60 MB/s Transferring 8192 KBs in 4 2048 KB blocks ... 1224.59 MB/s Transferring 8192 KBs in 2 4096 KB blocks ... 1320.80 MB/s Transferring 8192 KBs in 1 8192 KB blocks ... 1342.77 MB/s PCIe Gen2.0 peak speed: 500MB/s/lane Writing 8192 KBs with block size (in bytes) below: Block_Size Avg Max Min End-End (MB/s) 524288 688.91 727.15 584.17 680.89 1048576 896.36 928.95 794.87 888.06 2097152 1060.30 1090.68 1040.20 1055.01 4194304 1133.18 1140.87 1125.60 1131.85 8388608 1155.83 1155.83 1155.83 1155.83 Reading 8192 KBs with block size (in bytes) below: Block_Size Avg Max Min End-End (MB/s) 524288 791.50 882.76 578.99 780.42 1048576 916.96 1010.60 829.17 911.15 2097152 1188.68 1224.59 1109.91 1183.89 4194304 1316.73 1320.80 1312.69 1312.16 8388608 1342.77 1342.77 1342.77 1342.77 Write top speed = 1155.83 MB/s Read top speed = 1342.77 MB/s Throughput = 1249.30 MB/s DIAGNOSTIC_PASSED
E:\altera\OpenCL>aoc --version Altera SDK for OpenCL, 64-Bit Offline Compiler Version 16.0.2 Build 222 Copyright (C) 2016 Altera Corporation
E:\altera\OpenCL>aoc -v kernel.cl aoc: Environment checks are completed successfully. You are now compiling the full flow!! aoc: Selected default target board de5net_a7 aoc: Running OpenCL parser.... aoc: OpenCL parser completed successfully. aoc: Compiling.... aoc: Linking with IP library ... +--------------------------------------------------------------------+ ; Estimated Resource Usage Summary ; +----------------------------------------+---------------------------+ ; Resource + Usage ; +----------------------------------------+---------------------------+ ; Logic utilization ; 43% ; ; ALUTs ; 24% ; ; Dedicated logic registers ; 20% ; ; Memory blocks ; 30% ; ; DSP blocks ; 6% ; +----------------------------------------+---------------------------; aoc: First stage compilation completed successfully. Error: Compiler Error, not able to generate hardware
qoc 1'st stage ..OK..1 CPU Core ~ about 1 min
quertus_map ..OK..8 CPU Cores ~ about 7GB RAM 30 min
quertus_cdb ..OK..1 CPU Core ~ about 2GB RAM 10 min
quertus_fit ..ERROR..1 CPU Core ~ about 2GB RAM 5 min
kernel_log
2018.01.18.19:26:10 Info: system: Done "system" with 170 modules, 550 files
quertus_sh_compile
Info: Quartus Prime Analysis & Synthesis was successful. 0 errors, 665 warnings Info: Peak virtual memory: 8145 megabytes
You are using Terasic's 16.1 BSP with Quartus 16.0.2. The BSP version must match the Quartus/AOC version. Update both Quartus and AOC to v16.1.2 If the problem still persisted, attach your full "quartus_sh_compile.log".
Thanks, I havn't seen that, I will change it now, and try again.
(and could someone delete my double post,thx)
