Hi all,
I am running niosII UDPoffload reference design from (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example). Everything goes on well until I met with removal timing violation on altera_reserved_tck of -2.243ns. The tck constraints look like following:# ---------------------------------------------------------------------------# JTAG interface input and output delays# --------------------------------------------------------------------------- set_input_delay \ -clock [ get_clocks altera_reserved_tck ] \ 10.0 \ [ get_ports { \ altera_reserved_tms \ altera_reserved_tdi \ } ] set_output_delay \ -clock [ get_clocks altera_reserved_tck ] \ 10.0 \ [ get_ports { altera_reserved_tdo } ] I noticed the following two lines are commented out:# create_clock -period 10MHz {altera_reserved_tck}# set_clock_groups -asynchronous -group {altera_reserved_tck} What's the root cause of these removal timing violations? Should I uncomment the above two lines (I assume altera tools will automatically create this altera_reserved_tck instead of user manually create in user's sdc, am I right)? FYI, the timing report is following: Critical Warning: Timing requirements not met Info: Worst-case removal slack is -2.243 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: -2.243 -2.243 altera_reserved_tck Info: 0.973 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[2] Info: 1.004 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[0] Info: 1.007 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[1] Info: 1.017 0.000 clkin_125 Info: 1.024 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|scan_clk|q_clock Info: 1.393 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[4] Info: 2.094 0.000 test_sys_sopc_inst|the_enet_pll|the_pll|altpll_component|auto_generated|pll1|clk[1] Info: 2.521 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[3] Info: The Metastability Analysis global option is set to OFF. Warning: The launch and latch times for the relationship between source clock: altera_reserved_tck and destination clock: test_sys_sopc_inst|the_enet_pll|the_pll|altpll_component|auto_generated|pll1|clk[1] are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0. Warning: The launch and latch times for the relationship between source clock: altera_reserved_tck and destination clock: test_sys_sopc_inst|the_enet_pll|the_pll|altpll_component|auto_generated|pll1|clk[1] are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0.链接已复制
1 回复
Yes, you should uncomment those two lines in order to avoid the fake timing violation warning.
I had the same problem. If you search the forum, you'll find a few posts which refer to this anomaly. Regards
