altfp_exp problem
hi all
I want to insert altfp_exp megacore function to my block diagram. However, I have a problem. when I try to insert altfp_exp megafunction, a message such "loading megawizard" is visible in the screen, and the megawizard has not started. May anyone send me a simple design with clk_enable and design files..
i added the requested block to the other thread. curious if you have tried 10.0. i couldn't reproduce this in 9.1sp2
ok.. thank you very much.. ı downloaded that file...problem is solved..
