17257 Discussions
problem in connecting a custom H/W using avalon memory mapped
Dear Guys
i have a question in quartus
i want to add an Avalon memory mapped interface to the SOPC builder
of an example project, and i want to connect my custom H/W as a memory
mapped component using the avalon memory mapped interface (conduit)
The problem is that: The top level entity of the project is in
verilog, and i don't know how to connect my custom H/W to the avalon memory mapped using verilog as i am not familiar with verilog.
the project is called application selector
you will find it on the altera website
Attached is the top entity verilog file, i tried to connect my H/W
(simple.vhd) by writting in that file, but an error occured
This is the error message:
Error: Port "coe_UID_export" does not exist in macrofunction
"cycloneIII_3c25_niosII_application_selector_sopc_instance"
can anybody help me?
and thank you in advance
Okay, so you either have already or still need to perform the following steps:
1 - Create a custom SoPC Builder component that exports your HW interface through a conduit.
2 - Generate your SoPC system.
Once this is done you should see a file:
"cycloneIII_3c25_niosII_application_selector_sopc_inst.v".
This file should contain an example instantiation of your SoPC system including your new exported conduit ports. In other words, this is showing you what the names of the ports are and how to connect them. Use this as an example as you modify the real SoPC system instantiation in your top level file.
Jake
Thank you so much Jake
God bless you :)
