I am using the following:
1. quartus 11.1 sp2 2. modelsim altera starter edition 10.0c 3. arria v i have created an altmult_add using the megawizard, and the following was created: component fakir_1_altmult_add_coef PORT ( aclr0 : IN STD_LOGIC := '0'; clock0 : IN STD_LOGIC := '1'; coefsel0 : IN STD_LOGIC_VECTOR (2 DOWNTO 0); dataa_0 : IN STD_LOGIC_VECTOR (11 DOWNTO 0) := (OTHERS => '0'); datab_0 : IN STD_LOGIC_VECTOR (11 DOWNTO 0) := (OTHERS => '0'); ena0 : IN STD_LOGIC := '1'; result : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component; i am using this component in my design, but when i try simulating it i recieve the following warning in the modelsim: ** Warning: (vsim-3473) Component instance "altera_mult_add1 : altera_mult_add" is not bound.# Time: 0 ps Iteration: 0 Instance: /fakir_calc_tb/fakir_1_altmult_add_coef_1/fakir_1_altmult_add_coef_mult_add_3fh4_component File: C:/Repositories/HD3.0/RedTailedHawk/RTL/IWP/fakir/fakir_calc/fakir_1_altmult_add_coef.vhd and the simulation results in an 'U' output from this component, i can't find the reason for it. help is requiered. Thanks.Link Copied
sounds like you havent added the source file for the alt mult add to your project. WHat you show is just the component declaration.
--- Quote Start --- sounds like you havent added the source file for the alt mult add to your project. WHat you show is just the component declaration. --- Quote End --- i have 2 files for the simulation: 1. test bench file, in which the component altmult_add is declared as: component fakir_1_altmult_add_coef PORT ( aclr0 : IN STD_LOGIC := '0'; clock0 : IN STD_LOGIC := '1'; coefsel0 : IN STD_LOGIC_VECTOR (2 DOWNTO 0); dataa_0 : IN STD_LOGIC_VECTOR (11 DOWNTO 0) := (OTHERS => '0'); datab_0 : IN STD_LOGIC_VECTOR (11 DOWNTO 0) := (OTHERS => '0'); ena0 : IN STD_LOGIC := '1'; result : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component; and instanciated as: fakir_1_altmult_add_coef_1: fakir_1_altmult_add_coef port map ( aclr0 => reset_calc_signal, clock0 => clk_signal, coefsel0 => "000", dataa_0 => dataa_0_signal, datab_0 => dataa_1_signal, ena0 => ena0_signal, result => result_signal); 2. the megawizard generated .vhd file of this component.
Aha, now I read in more detail. altera_mult_add annoyingly is not in the default altera libraries, you have to add the altera_insim_components to your modelsim project, and or create a library for it.
you can find the altera_insim_components.vhd in: <quartus install dir>/eda/sim_libs/ I also suggest you raise an enhancement request via mysupport to fix this - its very annoying.- Mark as New
thanks, i will try it!
by the way, i am using arria v.- Mark as New
trued it, added the altera_insim_components.vhd to the modelsim project, still didnt work...
could it be related in any way to the fact that i m using the modelsim starter edition?- Mark as New
copy this file to sim project directory
C:\altera\13.0sp1\quartus\libraries\megafunctions\altera_mult_add_rtl.v and rename the module to altera_mult_add, add this .v file to modelsim project.- Mark as New
i feel Xilinx flow is much easier than Altera one, this takes me 1 hr to find out :(
