17253 Discussions
aoc: unable to generate hardware
I use de5a_net_i2 board, and I need to modify the bsp to change the PCIE interface lane to x4.
On linux 64bit OS, after I set ACL_QSH_COMPILE_CMD="quartus_sh --flow compile top -c base", I run the bash shell line "aoc vector_add.cl -v --no-interleaving default".
Then the compile stopped because of error
aoc: First stage compilation completed successfully.
Error: Compiler Error, not able to generate hardware.
The quartus_sh_compile.log file lists the following:
Error(18633):The archive "base.qdb" contains a full design and cannot be imported via the import block command nor as a source file in the QSF.
Can anyone help me?
Thank you!
