aocl diagnose error
hi
I installed the opencl SDK version 14.1.
When I typed the command aocl diagnose , i could find the device name acl0.
But I typed the aocl diagnose acl0 , there are some message happended.
Verified that the kernel mode driver is installed on the host machine.
FAILED to read auto-discovery string at byte 14: Expected version is 13, found 11
Error: The currently programmed/flashed design is no longer supported in this release. Please recompile the design with the present version of the SDK and re-program/flash the board.
acl_hal_mmd.c:209:assert failure: Failed to initialize kernel interfacediagnostic: acl_hal_mmd.c:209: l_try_device: Assertion `0' failed.
aocl diagnose: failed.
Could anyone solve this problem ?
It seems as though your board wasn't flashed with the proper hardware image. It would have had to been compiled with version 14.1 OpenCL SDK. I would look at the getting started guide and your board vendor documentation for instructions to do so. Which board are you using?
Rudy
