17254 Discussions
Signaltap retrieve data .... after having plugged JTAG
is it possible to plug the jtag (usb blaster or other) and retrieve captured data (aquire data a postiori) with signaltap?
I mean :
  1. Program a FPGA with SignalTap,
  2. Let the board functionning alone, let internal SignalTap capture data because trigger has occured
  3. Plug USB Blaster
I know there is a power up capture, but I want to retrieve data after an other trigger condition was met.
Is it possible ?
notes :
(1) : Does SignalTap work alone in FPGA = without having to press "Run analysis" ?
(2) : Is there an risk of loosing FPGA configuration when pluggin USB Blaster ?
Cordially.
--- Quote Start ---
I mean :
  3. Plug USB Blaster
Is it possible ?
notes :
Cordially.
--- Quote End ---
Why can't you do it in the usual order?
1. Plug in USB BLASTER
2. Launch Quartus > SignalTap program the FPGA with SignalTap
3. Let the board function and capture data when it triggers.
4. Download data.
I try to find a cause of a disfunction that stops a system : it occures at 1 min or lots of days after power-on.
Because JTAG can reconfigure FPGA, I prefer NOT plugging USB Blaster when the board is functionning. The risk is too important.
I made a "datalogger" board but it captures onl a few signals wich are not significant enough.
So I would like to offload data from Signaltap AFTER triggered (and after securizing the system).
I think you would need USB blaster connected for the SignalTap to run. I believe the data is real time streamed into the PC which are connected to the board.
I think too.
That is a risky solution.
So I am on other way.
Why not just leave the USB-Blaster plugged into the board? That way the USB-Blaster is not "hot-plugged" into the JTAG header while your board is powered.
You could leave the USB-Blaster plugged into a PC, so that the cable electronics is also powered, but that is not required. You could just plug the USB-Blaster USB connector into your PC after the board has been powered.
SignalTap II has a power-on trigger configuration. This allows the FPGA instance of SignalTap II to trigger, and then you can retrieve the trace at a later time. I have used this to capture an event that would only occur every few days.
Cheers,
Dave
Because JTAG can set the FPGA into a high impedance which is catastrophic in my system, I can't allow that.
--- Quote Start ---
--- Quote End ---
NOT sure. I had burnt USB Blasters this way, I think.
--- Quote Start ---
--- Quote End ---
Only if the TAP machine is programmed to issue the HIGHZ command. Its unlikely to randomly issue this command.
--- Quote Start ---
--- Quote End ---
It should work fine. The VCC_OUT voltage from the 10-pin header goes to dual-voltage buffers that are tolerant of either supply powered before the other.
Cheers,
Dave
