some questions,
how to auto assign pins and make sure that if I re-compile the design , the ports will be assigned to the same pins always ? Is there any crucial difference between quartus II v9.1 and 8.2? thanks....Link Copied
Make sure you use 9.1 SP2 or 9.0 SP2
AFAIK the only way to make sure the pins do not change is to assign them.- Mark as New
After you compile a design, you can back annotate the automatic assignments. The "Back Annotate Assignments..." option is in the "Assignments" menu.
quartus 9.1 has the niosII-e cpu for free :-)
