17266 Discussions
basic always block question
I have questions about always blocks. Both will use the following always block for context:
always @ (posedge Clk) begin if (x1) q <= 1; else if (x2) q <= 0; else q <= q; end
where q, x1 and x2 are all 1 bit wide.
Would this code 'prioritize' checking x1 before x2? What would happen if x1 and x2 were both high?
How exactly would it synthesize?
Also, if I want q to retain it's value, is it necessary for me to explicitly code that in the form of q <= q? or is there another way?
--- Quote Start ---
--- Quote End ---
Obviously yes.
--- Quote Start ---
--- Quote End ---
The same as only x1 high?
--- Quote Start ---
--- Quote End ---
Any logic fulfilling the behavioral description would be correct. In FPGA as D-FF with preceding logic. You can watch the synthesis result in Quartus post synthesis net list.
--- Quote Start ---
--- Quote End ---
The final else statement is redundant and can be omitted. A register keeps the previous state by default.
