baud rate recognizer
Contributeur émérite II
1 455 Visites
hi guys , i need to build a baud rate recognizer as part of a serial communication reciver.
the baud rate recognizer , recives 31h as the first signal and based on it, recognizes the rate.
( 2400, 9600, etc ). does anyone has an idea how should i do it ? cause i'm really clueless ...
0 Compliments
3 Réponses
741 Visites
I would say that you have to generate all the baud rate possible, receive the data and check with the which one you receive well the preamble.
Jérôme
0 Compliments
741 Visites
hi in which application ur using the bit rates depends upon the type of application either in communication wt micro-controller r any other it depends
as above lets mentioned u need to generate the baud clks wt respect to ur reference clk
0 Compliments
741 Visites
If you only need to support a relatively small number of baud rates, you could synthesize several UARTs in parallel, one for each baud rate. Then, you just wait for one of the UARTs to correctly receive the 31h.
A more traditional approach would be to measure the time between transitions when receiving the 31h. For example, you could measure the time of the start bit. From this, you can calculate the baud rate.
0 Compliments
Répondre
