17251 Discussions
can anybody help me in to remove this error......! full_adder.vhd(18): near "is": expecting: END in following code of full adder......!
MNaee
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity full_adder is
port ( -- Eingaben
a    : in std_logic ;
b    : in std_logic ;
c    : in std_logic ;
sum_full   : out std_logic ;
carry_full  : out std_logic
end full_adder;
architecture behavior of full_adder is
signal sum1, sum2 ,carry1, carry2 : bit ;
component half_adder is--asc
port ( -- Eingaben
   a    : in std_logic ;
   b    : in std_logic ;
   sum   : out std_logic ;
   carry  : out std_logic
 end component half_adder;
begin
p1 : process
begin
HA1 : port map half_adder (
        a => a,
        b => b,
        sum => sum1 ,
        carry => carry1
HA2 : port map
      half_adder(
        a => sum1,
        b => c,
        sum => sum2 ,
        carry => carry2
end process;
  sum_full <= sum2 ;
  carry_full <= carry1 or carry2 ;
end behavior;
Abe
Valued Contributor II
First off, there are quite a few issues with your code. I'll highlight them here:
  1. You've declared sum and carry outputs as std_logic, while the intermediate signals carry1, etc as bit. This is a type mismatch. You need to declare these also as std_logic.
  2. You've used a process for generating combinational logic. The general rule of design is that we use continuous assignments for combinational logic and Process for sequential logic.
  3. When using a Process, you must specify a Sensitivity list, ex, Process (a,b,c). If you do not specify this , the compiler may treat this as an infinite process loop and can generate errors.
  4. The Port mapping is wrong, it should be as
label/instance_name : component_name Port Map
Make these changes to your code and it will compile without errors.
Tricky
New Contributor II
You are trying to instantiate components inside a process. You can't do that
Abe
MNaee
Thanks for the reply........!
problem is resolve by correct instantiation, removing process and and declaring signal as std_logic, also i removed 'is' and 'half_adder' near end of component declaration.
