17255 Discussions
can someone help on this
Hi all,
I am working on a finite state machine assignment. I have the following code below which i want key_0, key_1, key_2 and key_3 to influence the out LEDR[1..0] and LEDG[1..0]. key_0 and key_1 work very well when pressed the LEDG lights come on but i donot understand why key_2 and key_3 does not affect the LEDR lights when i run the code on the DE2-115 altera circuit board. I have tried to modify the code several times but still nothing happens. Thank you vhdl gurus for helping:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector (1 downto 0); -- Output
LEDG : out std_logic_vector (1 downto 0) -- Output
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,unlocked);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
begin
-- Synchronous Process
process(clk, reset)
begin
if( reset = '1' ) then --Synchronous Reset
Current_State <= closed;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
Process(Current_State, key_0, key_1, key_2, key_3)
begin
LEDG <= "00"; LEDR <= "00";
case Current_State is
when closed =>
if ( key_0 = '1' ) then
Next_State <= closed;
LEDG <= "01";
else
Next_State <= opened;
LEDG <= "10";
end if;
when opened =>
if ( key_1 = '1' ) then
LEDG <= "10";
else
LEDG <= "01";
end if;
when locked =>
if ( key_2 = '1' ) then
Next_State <= locked ;
LEDR <= "10";
else
Next_State <= unlocked;
LEDR <= "01";
end if;
when unlocked =>
if (key_3 = '1' ) then
LEDR <= "01";
else
Next_State <= locked;
LEDR <= "10";
end if;
when others =>
NULL;
end case;
end process;
end Behavioral;
:confused: thanks for helping
I don't see a way to transition into your "locked" state. Looks like you can only transition between the closed and opened states.
Another tip - do not define a NULL others case in an asynchronous process, you risk producing latches- but you are already producing latches by not assigning LEDR and LEDG in ALL states (the synthesisor may have removed locked and unlocked for being states that cannot be entered, and hence no latch warnings).
--- Quote Start ---
--- Quote End ---
Thank you for valuable tips cronus10 and tricky
Thank you Tricky for your valuable help
Can someone still help on this? I am still having some problems even after assigning LEDR and LEDG in all the states. The different states do not work independently, by this i mean
press Key_0 and LEDG[0] lights, press key_1 and LEDG[1] lights, press key_2 and LEDR[0] lights and press key_3 and LEDR[1..0] and LEDG[1..0] all light.
Hoping to read from vhdl gurus.....................thanks in advance
The main problem before was that there was no way to get into the locked and unlocked states. did you fix this?
Hi Tricky, i have tried to fix the locked and unlocked states, see how the code looks, hope i am on the right track? i am an amateur in vhdl
library IEEE;
LEDR : out std_logic_vector (1 downto 0); -- Output LEDR
LEDG : out std_logic_vector (1 downto 0) -- Output LEDR
end uppgift_dorr;
begin
process(clk, reset)
begin
end if;
end process;
begin
when closed =>
else
LEDG <= "01"; LEDR <= "01";
end if;
when opened =>
else
LEDG <= "11"; LEDR <= "10";
end if;
when locked =>
LEDG <= "11"; LEDR <= "11";
else
LEDG <= "10"; LEDR <= "00";
end if;
when unlocked =>
else
LEDG <= "10"; LEDR <= "10";
end if;
end case;
end process;
end Behavioral;
You still cannot get into the locked or unlocked states. Hence they are probably removed.
Closed -> Opened -> closed.
Hi Tricky, Thanks for the fast reply, probably now i have got into the locked or unlocked states, do you mind checking out the combinational process:
begin
when closed =>
else
end if;
when opened =>
else
end if;
when locked =>
Next_State <= opened ;
else
end if;
when unlocked =>
else
LEDG <= "10"; LEDR <= "11";
end if;
end case;
end process;
end Behavioral;
Now all states are possible - does it work? have you run a testbench?
--- Quote Start ---
--- Quote End ---
Hi Tricky thanks again for your reply, i have run a testbench but still it does not work the way i want: i intend to have
Key_0 pressed and LEDG(1) comes on (lights)
Key_1 pressed and LEDG(0) comes on (lights)
key_2 pressed and LEDR(1) comes on
Key_3 pressed and LEDR(1), LEDR(0), LEDG(0) and LEDG(1) signifying it has come to some kind of error state which in this case is unlocked
Below is the testbench i created can you still please take a look, other proposition from forum members are welcome as well. Feel free forum friends to add any comments that can be of help:
-- Vhdl Test Bench template for design : uppgift_dorr
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uppgift_dorr_vhd_tst IS
END uppgift_dorr_vhd_tst;
ARCHITECTURE uppgift_dorr_arch OF uppgift_dorr_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC := '0';
SIGNAL key_0 : STD_LOGIC;
SIGNAL key_1 : STD_LOGIC;
SIGNAL key_2 : STD_LOGIC;
SIGNAL key_3 : STD_LOGIC;
SIGNAL LEDG : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL LEDR : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL reset : STD_LOGIC := '0';
COMPONENT uppgift_dorr
PORT (
clk : IN STD_LOGIC;
key_0 : IN STD_LOGIC;
key_1 : IN STD_LOGIC;
key_2 : IN STD_LOGIC;
key_3 : IN STD_LOGIC;
LEDG : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
reset : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : uppgift_dorr
PORT MAP (
-- list connections between master ports and signals
clk => clk,
key_0 => key_0,
key_1 => key_1,
key_2 => key_2,
key_3 => key_3,
LEDG => LEDG,
LEDR => LEDR,
reset => reset
clk <= NOT clk after 20 ns; -- 50MHz
reset <= '0', '1' after 100 ns;
init : PROCESS
-- variable declarations
BEGIN
key_0 <= '1';
WAIT FOR 100 ns;
key_1 <= '1';
WAIT FOR 100 ns;
key_2 <= '1';
WAIT FOR 100 ns;
key_3 <= '1';
WAIT FOR 100 ns;
key_0 <= '0';
WAIT FOR 100 ns;
key_1 <= '0';
WAIT FOR 100 ns;
key_2 <= '0';
WAIT FOR 100 ns;
key_3 <= '0';
WAIT FOR 100 ns;
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
-- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
END uppgift_dorr_arch;
Not sure what you really want to hear - if you have a testbench then you should be able to debug the circuit yourself as you have access to all the waveforms in the simulation.
I will comment that the key presses hold the state machine In the state - and not change the state - is that what you intended?
--- Quote Start ---
--- Quote End ---
Thanks Tricky for all your help, i have tried to implement your comment by the having the kery presses to hold the state machine in the same state but i produced a whole lot more latches again.
I am struggling to see how i can get the code working properly. The funny thing about the wave form of the test bench in the previous case was that it gives only a few states of the code "00" and "10"
I will continue to see how i can breakthrough this rock, your comments are still very much welcomed
